Sponsored by: Real Truck
Stock Alarm Question....
Old Sep 26, 2011 | 12:42 PM
bpounds's Avatar
bpounds
Originally Posted by A/Ox4
Well if it's not an alarm, what's the panic button for? And how come when you press lock twice it honks? Is it for show.
That is keyless entry. It is not an intrusion/theft alarm. The panic button is just so you can push it if some big kids start chasing you.
Old Sep 26, 2011 | 12:46 PM
bpounds's Avatar
bpounds
Originally Posted by dchamberlain
Seems like we've been over this before. If there was a factory alarm, I'm pretty sure it'd be mentioned in the Owner's Manual, like these two features are. But it's not.
We have indeed. NO factory alarms on '99-07 Superduty. Only Ford branded dealer installed alarms.
Old Sep 26, 2011 | 06:39 PM
Sickler1's Avatar
Sickler1
so were do i look for this security box?
Old Sep 26, 2011 | 07:51 PM
bpounds's Avatar
bpounds
What security box? I am not sure what you are asking. But that won't stop me from going on and on with an answer.
What trim level is your truck? XLT, Lariat, something else? If it is Lariat or King Ranch or Harley, then it has keyless entry. If it is XLT, it might have keyless entry, because that was an option.
It seems like you have keyless entry, because your lights flash when you close a locked door. But if you have it, then you should have a 5 key pad on your drivers side door, and apparently you don't.
You can download a copy of your owners manual and it will tell you all about the keyless entry, and how to program new FOB's. (a fob is the thing on your key ring with buttons that you push) Your truck will tell you if you have keyless entry, if you follow the FOB programming instructions, and it responds. If it sits there acting dumb, then it doesn't have that option.
It is also possible that you have some 3rd party alarm or keyless entry. Look around under the hood and under the dash for signs of added modules that don't look original.
Without more info, that is about all I can tell you.
Old Sep 26, 2011 | 08:00 PM
Sickler1's Avatar
Sickler1
I was talking about like an alarm module or something but i think your rite about it just being keyless entry
It's a lariat
Old Sep 26, 2011 | 08:05 PM
bpounds's Avatar
bpounds
If it is a Lariat, it has keyless entry. Do you have the FOB's? Like Trey said above, you can buy FOB's on eBay.
The lights flashing when you close a locked door is normal with the keyless entry.
Do you have a keypad on the door? I thought that was part of keyless entry, but I could be wrong.
I have seen nothing in your posts that would make me think you have an alarm.
Old Sep 26, 2011 | 08:21 PM
dchamberlain's Avatar
dchamberlain
Dang. I learn something new every year or so.
I did not realize that if you locked the doors and then closed them that the lights flashed. That was throwing me off. So you probably do have keyless entry.
One way to make sure is to follow the procedure in the Owner's Manual to program key fobs. If the locks cycle when they should it's certain you have keyless entry and just need to buy fobs. And you can probably get a stick on keypad also.
Old Sep 26, 2011 | 08:37 PM
Hotpocket's Avatar
Hotpocket
Not to take over the thread or anything but my 04 has keyless entry and lights flash when a locked door is closed also...it can be locked manually and still does it. Also when you disconnect the positive cable from the battery an "alarm" (not the horn) goes off and stops off when completly disconnected but i have seen no sign of a switch or anything under the dash
Old Sep 26, 2011 | 09:11 PM
Sickler1's Avatar
Sickler1
no keypad on door...i didnt get fobs when purchasing truck...so ill just try the ebay thing! thanks for all the help everyone!
Old Sep 26, 2011 | 09:24 PM
bpounds's Avatar
bpounds
My '06 only flashes the lights if it is dark outside. When the automatic lights sense that it is daytime, they don't flash.
Old Oct 4, 2011 | 05:34 PM
Sickler1's Avatar
Sickler1
Ok so I got my new key fob in mail....programmed it and bang keyless entry...but when I hit the lock button the horn honked...so I thought maybe it had an alarm so i hit the red button an ban alarm too....
Old Oct 4, 2011 | 05:36 PM
Sickler1's Avatar
Sickler1
So Idk if this proves some people wrong...but I did order the factory ford key fob n I have keyless n alarm on my 03
Old Oct 4, 2011 | 06:40 PM
  #28
bpounds's Avatar
bpounds
Keyless Entry works like this: hit the lock button once and the doors lock. Hit the lock button a second time, and the horn honks once if all is okay. The horn honks twice if a door is not closed.
The red button is a panic button. It is not an intrusion alarm. It is used to set off the horn if you feel threatened, to call attention of others for help. That is not an alarm by my definition, but you can call it what you want I guess. Guaranteed it will not go off honking if someone breaks your window or jimmies your door.
Old Oct 4, 2011 | 07:57 PM
  #29
Pili's Avatar
Pili
Question, if you lock the truck with the fob (pushing the lock button twice) and you unlock it with the key does the horn go off?
dirtymutt
Apr 26, 2017 08:36 PM
roostonu
May 5, 2006 03:03 AM
Walt750
1997 - 2003 F150
Nov 17, 2003 06:12 PM
mixexpy
Sep 22, 2003 10:39 AM
