diff vents
Old Sep 25, 2011 | 11:16 AM
collinft's Avatar
collinft
diff vents
i have a few ?s on diff vents on a 78 f150 with d44 and ford 9".
1-are they supposed to have hoses on them running to the highest point?
2-how do i service or unplug them?
3-could a plugged vent cause my rear axle seal leak?
4-do i hook up the hoses to something solid or let them have some play?
thanks
Old Sep 25, 2011 | 11:39 AM
brian1080's Avatar
brian1080
1-yes, the hose just runs up to the frame somewhere, hook it with a ziptie
2-take them off, run wire or a small drill bit through them (you should see right through them) and clean them out
3-yes, the pressure has to go somewhere
4-the open end just hangs loose, once you have it secured up high enough not to get water in it
Old Sep 25, 2011 | 12:14 PM
HIO Silver's Avatar
HIO Silver
thanks
4 - Concur with zip-tying it. It should have enough slack to account for the suspension at full extension. Some desert racers run the lines to a filtered breather.
Old Sep 25, 2011 | 12:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's how the rear vent is done from the factory.
Old Sep 25, 2011 | 01:32 PM
collinft's Avatar
collinft
thanks for the info and pics everyone.
Frdaxl
Aug 20, 2010 05:44 PM
crestfallinman
23
Dec 20, 2008 03:58 PM
Big Rig
Modular V10 (6.8l)
Aug 25, 2005 11:00 AM
jenks47
Sep 11, 2004 07:46 AM
mustang
Apr 16, 2000 10:50 PM
