1978 heater motor
Old Sep 25, 2011 | 12:07 AM
jimmy dale's Avatar
jimmy dale
1978 heater motor
78 ford f150 no ac
So it was real easy to remove 3 nuts and gave her a yank
lol
ok so here is the question the fan motor has a hole in the top of it and as we look at new 1's they do to what is it for or is it important
could it be for extra cooling of motor?
if so what goes on it to prevent water from getting in it is a big hole and the one we took off had 100 mph tape ( duct tape ) covering it
thanks for reading this and if you have any idea what or where to look to find out why please give me a holler
thanks jimmy dale
Old Sep 25, 2011 | 06:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Was the one that you took off original or also a replacement? The originals didn't have a vent hole.
This is strictly a guess on my part. The aftermarket often use the same basic part to cover many applications to save money. The Econoline heaters did use a vent hole in the housing. This had a short hose attached to it. Perhaps the manufacturer uses the same basic motor housing for both the F and E versions of the blower motor.
This is the illustration from the Ford parts catalog for the Econoline heater.
Clic on the .pdf link to view.
File Type: pdf
Old Sep 25, 2011 | 09:34 AM
jimmy dale's Avatar
jimmy dale
thanks yup it has the hole i might not be original
we are the 3 rd owner and it belonged to a school dist as a snow plow for 20 years so cant even confirm it either way
but yes the diagram helps i will make something to keep water out and air flow open just in case there duct tape was probably a bad idea if it needed air
northerndave
42
Oct 15, 2021 01:16 AM
CharlieXLT
Apr 13, 2018 05:40 PM
tjdad62
Aug 6, 2014 11:29 AM
Chevmn56
Nov 16, 2013 09:47 PM
fordblue_ca
Oct 27, 2003 11:46 AM
