Mild upgrade help
Old Sep 27, 2011 | 10:50 AM
  #31
Lovin7.3's Avatar
Lovin7.3
Originally Posted by tex25025
That is somewhat the same thing that a RR kit would do. I just don't think either FASS or AirDog eliminates the dead-heading.
So would a AirDog with a cross connect eliminate the dead heading?
Old Sep 27, 2011 | 10:54 AM
  #32
tex25025's Avatar
tex25025
People use the Fuel CrossOver for that purpose. I'm on the fence as to if the crossover does the job fully, but people do use it for that purpose.
Old Sep 27, 2011 | 11:15 AM
  #33
Lovin7.3's Avatar
Lovin7.3
So if you could only have one (airdog/fass or RR) what would it be?
Old Sep 27, 2011 | 09:03 PM
  #34
Lovin7.3's Avatar
Lovin7.3
or would you do both?
Old Sep 27, 2011 | 09:05 PM
  #35
tex25025's Avatar
tex25025
I did both, some would argue that you really shouldn't have to do both.
If you aren't planning to do any moderate modding to the truck, I would vote to go with the RR Kit as I'm not a fan of dead-heading design. That just really lends itself to starving those last 2 injectors.
That's just me though.
Old Sep 27, 2011 | 09:11 PM
  #36
Lovin7.3's Avatar
Lovin7.3
What do you consider Moderate Mods?? lol everyones version of thats different.
Old Sep 27, 2011 | 09:20 PM
  #37
tex25025's Avatar
tex25025
When you start dealing with bigger injectors. I think Stage Is are borderline for what the stock pump can handle. Some would say that it can handle more then even those injectors, I tend to error on the side of caution. However, when you start talking Stage II and IIIs, then I would go for both mods (pump and RR kit).
Old Sep 27, 2011 | 09:24 PM
  #38
Lovin7.3's Avatar
Lovin7.3
Thanks for the help. Ill be getting the blue fuel spring and checking the oil cooler. Thanks
Old Sep 28, 2011 | 04:41 AM
  #39
npccpartsman's Avatar
npccpartsman
IMHO a crossover is basically another form of deadhead (and a waste of money). If you put equal pressure on both ends of a pipe what happens to the material in the middle? It sits there and STILL has no where to go. If the fuel supply is adequate there's nothing to suggest that the back two injectors should or will starve even with a deadhead design.
Old Sep 28, 2011 | 06:24 AM
  #40
tex25025's Avatar
tex25025
That's the question right there.
Old Sep 28, 2011 | 06:56 AM
  #41
npccpartsman
Which is why you need to start with a fuel pressure gauge and go from there.
The only real benefit from my RR that I've seen is that it eliminates the crappy stock fuel pressure regulator.
LMAO--I could type an "Evan style" dissertation on fuel systems if I really wanted to get started but it's not worth all the speculation and over thinking it might start.
Old Sep 28, 2011 | 07:15 AM
  #42
bismic's Avatar
bismic
100% agree w/ ya Tim!
Old Sep 28, 2011 | 07:26 AM
  #43
tex25025's Avatar
tex25025
Oh that can't be good for me.
Old Sep 28, 2011 | 03:33 PM
  #44
npccpartsman
HAHA.......it's all good, my friend. We are here to discuss and help our fellow 6.0'ers from our trials and tribulations because we've BTDT and have the PHD to prove it.
Old Sep 28, 2011 | 08:01 PM
  #45
Lovin7.3's Avatar
Lovin7.3
Should i change to 6.4 banjo bolts and do something with the coolant too?
