Mild upgrade help
Old Sep 23, 2011 | 10:08 PM
Lovin7.3's Avatar
Lovin7.3
Mild upgrade help
Well after two years of keeping my truck stock its time for some upgrades. So this afternoon I ordered: ARP headstuds, EGR delete, all new gaskets for the top end, SCT SF3, and a Powermax Turbo.
Sooooo.... Im pulling the cab in 5-6 weeks and I have been searching all the posts to see what else I should do while I have the cab off and motor apart. Ive been looking through threads so long i cant think anymore. lol
I knew my 7.3 like the back of my hand but I havnt messed with the 6.0 much yet. Any tips and part numbers for the other stuff I need would be great.
What I dont want to do is.... Injectors(dont want them) or a regulated return(getting the wife to let me come off the money for the turbo was hard enough )
Thanks for the help and ideas.
Old Sep 23, 2011 | 10:15 PM
BLADE35's Avatar
BLADE35
Hows your Oil Cooler
Old Sep 23, 2011 | 10:20 PM
Lovin7.3's Avatar
Lovin7.3
Not sure. Is that something I should just replace while Im in there?
Old Sep 23, 2011 | 10:32 PM
BLADE35's Avatar
BLADE35
to check the oil cooler the truck needs to be fulley warmed up and after temps stabilize at 65 mph and then compare ECT vs EOT no more than 15 degree spreed
You will be right there once you get all the stuff off the top of the moter
Its a 215.00 $$ part at
www.partsguyed.com
Old Sep 24, 2011 | 05:49 AM
npccpartsman's Avatar
npccpartsman
How about some particulars on your truck such as mileage, brand of filters and oil/weight. It helps if we know these things.
Things to do while you're in that deep: Oil cooler if needed, STC fitting unless it's been replaced, blue spring upgrade in the fuel pressure regulator (easy any time).
Old Sep 24, 2011 | 07:38 AM
tex25025's Avatar
tex25025
For those that for one reason or another don't want to do the RR kit do the Fuel CrossOver. Some say it's good enough, I dunno. I think that the RR kit is well worth the money involved, but that's just me.
Old Sep 24, 2011 | 09:38 AM
Lovin7.3's Avatar
Lovin7.3
Truck has 95K miles. I use motorcraft oil and filters. Havnt had any problems with the truck but Im wanting to tune it so Im taking the steps to do so. Where can I get the SCT fitting kit and I guess I dont understand how you check to see if the oil cooler is bad or not.
Old Sep 24, 2011 | 10:27 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You need a Scan Gauge. Highly recommended if you don't have gauges. Program it to show Engine Oil and Coolant temps.....
Old Sep 24, 2011 | 10:43 AM
Lovin7.3's Avatar
Lovin7.3
I have pre ordered the new Quadzilla Vizion but it hasnt been released yet
Old Sep 24, 2011 | 10:47 AM
Piolet's Avatar
Piolet
Ford 6.0L Power Stroke Problem Solvers - Diesel Power Magazine
This article helps to understand the relationship of the oil temp and coolant temp, and has photos of the parts involved. I don't mean to confuse you with the talk here of the cooler swap ... it's just an easy cut & paste to explain a lot.
With an Edge Insight or a Scangauge II you can read what the realtime oil and coolant temps are. If the spread is over 15 deg F you likely have a clogged oil cooler. If the spread is less than 8 you are fine. If the spread is between 8 - 15 you may need to start reading about coolant system maintenance and backflushing the oil cooler to avoid expensive and labor intensive repairs.
BLADE35 is refering to addressing this cooler while you are in there if it's necessary.
Best of luck with all the work!
Old Sep 24, 2011 | 01:18 PM
2006powerstroke90's Avatar
2006powerstroke90
I think working on a 6.0 is easier than a 7.3 IMHO
Old Sep 24, 2011 | 01:28 PM
Lovin7.3's Avatar
Lovin7.3
Thanks for all the info. Who makes the fuel cross connect kit?
Old Sep 24, 2011 | 01:46 PM
2006powerstroke90
6.0L Powerstroke Diesel Fuel Crossover Line Kit
Ford 6.0L PSD Crossover Line with a fixed orifice
Old Sep 24, 2011 | 04:45 PM
Lovin7.3's Avatar
Lovin7.3
Do I need to do anything with my coolant? And what fluids should I be running?
Old Sep 24, 2011 | 05:51 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
While u have the heads off. Should do Standpipes & Dummy plugs to. An I wood do a coolant flush before I took it apart an then change oil cooler an once back together I would put a coolant filter on it.
