Hi everyone,I have an1988 f-150 4x4 with a 302 completely stock,i think, and my alternator is on its way out i believe its a 75 amp.Is there a higher amp one out there thats a bolt on?I plan on putting on a few 55w off road lights nothing to crazy.
As has been mentioned many times before the 130A 3G alternator swap out of a early/mid '90's Taurus will fit right in with a cable & fuse + a simple harness modification.
... And do away with that fire hazard plug on the back of the 2G.
There are several configurations, so be sure you get the right one.
A recent thread here reminded me just how important it is to do your homework.
Originally Posted by LCAM-01XA
There are at least three styles of 3G alternators, you need to pick the one that matches the style of alternator that you have in your truck right now:
a) if you have a pivot-mount small-frame alt (7" distance between mounting holes) you need an alternator for a mid-late-'90s Ford Taurus with the 3.0 V6 engine.
b) if you have a pivot-mount large-frame alt (8-1/4" distance between mounting holes) you need an alternator for a mid-late-'90s Ford Taurus with the 3.8 V6 engine.
c) if you have the side-mount alternator you need an alt for a '97 PSD.
These are all 130-amp alternators, there are also 95-amp 3G units in existence but they are not what you want even tho they will bolt up if you pick the correct one.
