White smoke....HELP
Old Sep 23, 2011 | 08:34 PM
belas's Avatar
belas
Not yet, went by the shop and tried to start it for the hellofit. After an hour of battery recharging it finally started, and I wish I would have recorded the sound. OMG. Never heard a truck sound like this before. Kinda like getting kicked in the ***** by a....well,it was bad. Had to continue to step on pedal to keep it running. Finally died, after 4 or five times like this, I plugged in the heater block for a minute, it brought temp up to C level and it idled, rough as hell, but idled. I did notice durring all this that the oil pressure gauge would not move, when it did, the truck fired off. Had some trouble codes from my Superchip tuner, 1-something about the ICP 2-KAM 3-EBP
My guess before I take it to Ford next week is the fuel pump, any other guesses?
One more thing, the had 2 injectors replaced this year, the old ones had NO o-rings....
Old Sep 23, 2011 | 08:37 PM
medhvac's Avatar
medhvac
did it knock really bad?
Old Sep 23, 2011 | 08:57 PM
belas's Avatar
belas
Oh yes..............
Old Sep 23, 2011 | 09:04 PM
medhvac's Avatar
medhvac
sounds like its time to replace all the injectors' with new ones! u can do it yourself its not that hard i did it lol
Old Sep 23, 2011 | 09:24 PM
medhvac's Avatar
medhvac
its easy to find out w/injector is bad!well maybe not,remove both vale covers unplug each injector 1 at a time start truck if it runs smooth u found it!
Old Sep 24, 2011 | 12:19 AM
kawcrasher's Avatar
kawcrasher
If you have a mechanic the can't diagnose problems, you don't have a mechanic you have a parts changer. Do yourself a favor and find a mechanic that can work on your truck. Ford garages aren't know to be the best with these engines either.
Sxeautoworx
6.4L Power Stroke Diesel
Mar 26, 2014 03:39 PM
grassman2852
Jan 3, 2014 11:52 PM
suds
Apr 11, 2013 10:33 PM
mjtpolice76
Jul 10, 2010 08:48 PM
Mydiesel250
Jun 21, 2008 06:59 PM
