Where is my backup switch???
Old Sep 21, 2011 | 09:13 AM
nlareau's Avatar
nlareau
Trying to get the backup lights to work. 1977 F100, I6 motor with C4 transmission. I've search the forums and I have the exploded diagrams for the truck (all 900 pages).
I cannot find any clear picture of where the dad-gum switch is. The ford diagrams only show it with the manual transmission.
I know where the PNRD switch is on the column, but apparently there is another switch that turns on the backup lights. I've even found the wiring connector for it and the PO has a wire shorting out the two terminals.
Somebody please tell me where this stupid thing is hiding!
Old Sep 21, 2011 | 11:29 AM
mark a.'s Avatar
mark a.
Should be under the dash on the column.
Old Sep 21, 2011 | 11:39 AM
ford_pickup's Avatar
ford_pickup
Believe it or not that wire shorting the two together is actually stock, that is where the back-up light switch would be for a three on the tree, if the wire is gone the lights will not work, and as far as I know the neutral safety switch is also the back-up light switch
gfw1985's Avatar
gfw1985
Cranky Old Guy
C4 transmissions usually have it incorporated with the back light switch on the tranny.
Old Sep 21, 2011 | 11:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The back up light switch is part of the neutral start switch. 73-77 it's mounted on top of the steering column under the dash just ahead of the firewall. 78-79 it's mounted on the transmission like the picture gfw1985 posted above.
Old Sep 22, 2011 | 07:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/79 F100/350 Neutral Safety Switches.
The backup (reverse) lamps operate via the neutral safety switch.
C7TZ-7A247-A .. Neutral Safety Switch (Motorcraft SW-600).
Applications: 1967/77 F100/350 all A/T's / Steering Column mounted.
D8TZ-7A247-A .. C6 Neutral Safety Switch (Motorcraft SW-1489).
Applications: 1978/79 F100/350 / Transmission mounted.
D8TZ-7A247-B .. C4 Neutral Safety Switch (Motorcraft SW-1491).
Applications: 1978/79 F100/250 / Transmission mounted.
Old Sep 23, 2011 | 07:11 PM
hasteranger's Avatar
hasteranger
do you know which wires do what out of the harness?
Old Oct 15, 2012 | 07:37 PM
fiveofsevin's Avatar
fiveofsevin
Re: nss
I need the link in the bottom of the pic that gfw1985 posted. For a 79 f-100, 302, c-4. any help would be GREATLY appreciated.
Just a part number would be a major help. Tks A
Old Oct 15, 2012 | 11:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
By "link" do you mean the shift arm itself or the small stud that connects the shift arm to the linkage?
Old Oct 16, 2012 | 12:02 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here are both parts.
Lever assy, manual control
78-79 F100-150 w/C4
Marked D8TP-CA
D8TZ-7A256-C
Stud, trans. gearshift connecting rod adjusting
73-up E-F100/350
D3TZ-7B415-B
I've located several of the studs, still looking for the control arm
Dennis Carpenter Obsolete, Concord, NC has 1 (704) 786-8139
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Parts International, Farmers Branch, TX has 2 (972) 241-8730
Klimesh Motor Sales, Calmar, IA has 2 (563) 562-3241
Old Oct 16, 2012 | 12:42 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I was able to locate one of the arms.
Lever assy.
D8TZ-7A256-C
Earl Floyd Ford, Carrollton, KY has 1 (800) 732-2037
Old Oct 17, 2012 | 07:59 PM
fiveofsevin
Re:
Holy nopar's Batman, part numbers, awesome. I need the arm on the bottom. it connects to the rod. Mines tweaked/bent and the gearshift indicator is off on the collum. Tranny shop said "good luck finding one".
I knew it would be here or "evilbay". Dont think I need a nut/bolt I'll crawl
back under tomorrow and have a look at it.
Cheers A
work.truck
Electrical Systems/Wiring
Dec 14, 2014 08:41 AM
lazerf250
Dec 8, 2008 11:15 PM
culiv
Oct 11, 2004 10:47 PM
Phaeton16
1966 - 1977 Early Broncos
Dec 11, 2001 10:33 AM
RAILMAN
Mar 14, 2001 11:25 PM
