straight pipes on my 02 powerstroke
Hey guys I just bought a 2002 7.3 powerstroke and I wanna put stacks on the truck the kit that I'm buying gives me straight pipe from the turbo back is it ok to alimenate the muffler and run straight pipe or will running straight pipe cause me to loose all my back pressure and possibly burn a valve out? I hear of guys running straight pipe on these diesels all the time. And it sounds really good but I'm afraid to do it myself until I get the right advice. Well that's it thanks for all the help
The noise dosant bother me I want it to be load lol but will it sound good or will it kinda sound like a gas v8 with no muffler? And I guess gas and diesel engines are different when it comes to that my uncle john is pretty mechanically inclined he was the one that told me I could burn out a valve because there would be no back pressure.
Who comes up with this garbage?!?!??!
The good news is it pre-dates the internet. Burnt valves were a problem for hot rodders more than the regular folk. Hot rodders and racers used to run straight pipes more often. Someone connected a couple of dots that shouldn't be connected.
If you think bad info spreads fast on the internet forums, travel back to a time when most of the country had fewer than a handful of TV channels, internet didn't exist, a larger percentage of the population would work on their own vehicles, and the dirt track and drag strip circuit was bigger because muscle cars were the in thing.
Sometimes it's just easier to say the turbo provides plenty of back pressure so you don't have to go down that whole road.
The issue with Valves stems from an imbalance in cooling causing "coaking / carbon deposits" on the exhaust valve preventing it from closing completely thereby exposing it to increased heat from combustion.
Basically a lack of heat that assists to complete combustion on the Power Stroke and inability to burn all gasses following the exhaust stroke.
The only complaints I hear is drone in the cab. Some say its worse on the Crew Cabs. Some people install resonators to help try to reduce it.
thecowboy
21
10-22-2004 07:33 PM
