Squeaky Brakes
Old Oct 2, 2011 | 10:19 AM
Dr. T's Avatar
Dr. T
[quote=7 I'm going to pull the pads, clean everything up real good and try applying some new anti-squeak compound to see if that helps. [/quote]
While you've got things apart you can also chamfer the leading edge of the pads.
Old Oct 2, 2011 | 12:25 PM
mhoefer's Avatar
mhoefer
Check for little rocks between pad and rotor and cyanides both leading edges. Do you drive on gravel roads much. I did have this problem on the 05 a few times, ravel on the roads for winter.....
Old Oct 2, 2011 | 04:28 PM
soling2003's Avatar
soling2003
For me, when they are hot from pulling the trailer they are worse. But the worst time was while on the Oregon coast with all the salt spray. So I think it has to do with good clean rotors and discs.
I agree with above though, it's embarrassing
Old Oct 2, 2011 | 06:47 PM
grafhky52's Avatar
grafhky52
Mine does it as well. by the way you state the wear indicator you must also have a bmw. many newer bmw have a sensor in the pad that makes the same sound as my truck. all customers for bmw get new pads if they complain. I have not mentioned this yet but have been thinking about it
Old Oct 3, 2011 | 07:15 AM
capt caper's Avatar
capt caper
I had a squeak or actually a squeal when rolling along without brakeing below 40mph. When I turned the wheel or applied the brakes it went away. I found the front drivers side pads were shot. The 2 piston caliper was probably freezing.Being one or both pistons in the caliper were freezeing or froze.
I pressed the piston back into the caliper and replaced both dr and pass side pads hopeing this will un freeze it but it won't I know I tried this on my 08 F350 and it didn't work. But this will buy me time to get a caliper ordered.
Funny thing is on both my 08 and this the front froze at 24k and the rear froze at 35k on the 08. So I'm expecting a rear noise in 5 or 10k miles on this 11.
It must be the way I drive and or things I tow while driving? Not many have these problems.
Youngm
1997 - 2003 F150
Aug 20, 2013 09:16 AM
awright48
1983 - 2012 Ranger & B-Series
Apr 19, 2011 10:47 AM
CounterMaker
Aug 19, 2009 05:39 PM
chapinmesa
Apr 22, 2009 09:47 PM
