Squeaky Brakes
Old Sep 20, 2011 | 11:43 AM
720Deere's Avatar
720Deere
Squeaky Brakes
Has anybody else experienced squeaky brakes when the truck is barely moving with the brakes applied? It is starting to drive me nuts during such maneuvers as inching up to an intersection or backing the camper into place. The best description I can give is it sounds a lot like the wear indicator, but it is more harmonic. I guess it is sort of like running a wet finger around a glass as far as the harmonics go.
Old Sep 20, 2011 | 11:45 AM
Marauder92V's Avatar
Marauder92V
Not here. You see any scoring on the rotors?
Old Sep 20, 2011 | 12:54 PM
720Deere's Avatar
720Deere
No scoring. It's not a grinding noise such as something stuck in a pad. It is a resonating sound resulting from friction and the rotor barely moving. It is slightly annoying, but I am picky. At least it beats the stuck calipers I have experienced before on these trucks!
Old Sep 20, 2011 | 01:20 PM
dschuffert's Avatar
dschuffert
Not in my '11 6.7. I had that with my '05 6.0 but not on this new rig.
Old Sep 20, 2011 | 01:27 PM
2000silverbullet's Avatar
2000silverbullet
I think my truck does the same thing you're describing 720Deere. When going from park to reverse/drive, it "barks" (seal bark in this case, not dog, lol) when lurching down the driveway...
Old Sep 20, 2011 | 01:37 PM
_red rocket_'s Avatar
_red rocket_
Squeaky brakes when moving slowly with brakes mildly applied, yes. I don't like it but I'm not concerned, yet.
Old Sep 20, 2011 | 03:19 PM
kper05's Avatar
kper05
High pitch or a groan (is how I describe it)?
Mine groan at slow speeds, such as backing into my garage.
Old Sep 20, 2011 | 05:42 PM
dualwheels66's Avatar
dualwheels66
Heat up the brakes with some good hard stops from 45 MPH. Then blow out the dust with compressed air. Sometimes just doing the hard stops works but I always do both.
Old Sep 20, 2011 | 08:55 PM
ruschejj's Avatar
ruschejj
I know what you mean. Just the way it is I suppose, funny because I know EXACTLY the noise you are talking about but never thought to bring it up here.
Old Sep 20, 2011 | 09:44 PM
cc2cuz's Avatar
cc2cuz
Yep, same thing happens to my truck, 11 6.7 lariat CC SWB. So I'm guessing this is normal huh?
Old Oct 1, 2011 | 07:56 PM
soling2003's Avatar
soling2003
Same thing with my 350 dually. After towing it is worse. Took it to the dealer and of course the said it is normal, especially if heated up from towing. If you find a cure let me know! The dealer said resurfacing the rotors would probably do it, but only for a short period.
Old Oct 2, 2011 | 12:41 AM
bigoltrk's Avatar
bigoltrk
Just a thought...I know you can't compare a F350 to a Fusion, but DW took her 2010 Fusion in yesterday for the fourth time in a year for "squeaking rear brakes".
Same story where they told her that it's normal or her imagination because they couldn't duplicate it. They turned the rotors and replaced the pads last time (about three months ago). Finally yesterday it did it when they test drove it and they couldn't believe how loud it was. It squeals when slowing from 5 to 0 MPH. They changed the rotors and pads.
I googled it for the Fusion and found a lot of complaints. I wonder if it's an anti-rattle clip or shim or new pad compound issue?
Old Oct 2, 2011 | 03:58 AM
soling2003's Avatar
soling2003
It does seemto be the brake pad comPound one tech said. But still......
Old Oct 2, 2011 | 06:03 AM
Adobe 11SD's Avatar
Adobe 11SD
Yes. I stop at a guard "shack" and badge in/out every day at work.
Almost always notice when slow rolling (5MPH or less) up to the badge reader and apply the brakes, it squeals pretty loud. It happens right before the truck comes to a complete stop.
It's kind of embarrassing.
Old Oct 2, 2011 | 08:11 AM
720Deere's Avatar
720Deere
That's my point exactly! It is embarrassing especially in a campground when you have a bunch of drooling Dodge and Chevy owners watching you. I know if it was me on the outside listening to that I would be thinking what is wrong with that POS!
Heating the brakes up does nothing for the noise. I have on several occasions heated them up pretty good (no it wasn't from a white knuckle ride off a mountain) and that did not help at all. When I get some time, I'm going to pull the pads, clean everything up real good and try applying some new anti-squeak compound to see if that helps. I don't think turning the rotors would help this problem as it doesn't seem to be as much of a friction noise as it is harmonics.
