6.0 white smoke problem
Old Sep 19, 2011 | 10:22 PM
F-250Power's Avatar
F-250Power
Having problem with my 04 f-250 6.0 blowing out white smoke only for about a minute after it is first started.seems to be coolant because if i turn the truck off and take the cap off the degas bottle to release the coolant pressure then the next time i start the truck she wont smoke.but if i leave it with the pressure built up then she will smoke next time start and have a dragging start.i have already done arp studs and gaskets and egr delete so was wondering if there was someway the coolant could get past the injector o-rings and into the cylinder.thanks for any help!
Old Sep 19, 2011 | 10:51 PM
BLADE35's Avatar
BLADE35
did you use motocraft head gaskets
other possibilitys are cracked heads, bad injector cups
does it loose coolant
429poweredf350
Jun 20, 2014 11:13 PM
ciscofreak
6.7L Power Stroke Diesel
17
Apr 4, 2014 01:59 PM
joe doyle
Aug 21, 2010 01:03 PM
1994diesel
Jul 20, 2008 09:00 PM
ktplotts
Jun 26, 2006 06:37 PM
