Blowing white smoke when cold
Old Nov 1, 2013 | 03:51 PM
ciscofreak's Avatar
ciscofreak
I have a 2013 and I've noticed that when pulling out on the highway in the mornings that my truck blows a pretty good amount of white smoke for at least 2 miles. Is this normal for a non-deleted truck? My 6.0 did this when it had injector issues but it was straight-piped.
I hooked up autoenginuity to the truck and noticed that the DPF load percentage was at 77%. I thought the truck goes in to active regen at 2.47%? The truck has been down on power and 6th gear is virtually useless unless going down hill.
Old Nov 1, 2013 | 05:32 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Is it white smoke or just tail pipe steam?
White smoke typically equals coolant, which when cold typically means head gasket has gone...
Has your truck consumed any coolant? If so, definitely worth taking to the dealer.
Old Nov 1, 2013 | 05:42 PM
parkland's Avatar
parkland
should be able to tell easily if it smells like coolant or raw fuel...
Old Nov 1, 2013 | 05:55 PM
senix's Avatar
senix
I'd certainly say normal if no coolant loss.
Old Nov 1, 2013 | 08:17 PM
kper05's Avatar
kper05
As the others said, if coolant is great then it's probably steam.
Mine creates quite a cloud behind me on cool but high moisture mornings and it's gone in a half mile since I have to jump on a 55 MPH highway.
If you want to test it, start it one morning and let it idle for about two minutes.
Then have someone keep the RPM's around 1,200 for another minute or so (unless you have high idle then turn that on).
That's about when the steam will really become strong and you'll be able to differentiate if it's steam or an actual issue.
Or drive it a few hundred yards and back (heats up more quickly) then have someone hold the RPMs.
I have 1,400 RPM high idle so after a minute or so on a cold morning the steam is pouring out of there in the driveway for at least a minute.
Old Nov 1, 2013 | 08:46 PM
Hdslider's Avatar
Hdslider
I like kyper live in a humid area. On a cold morning mine will blow steam out of pipe a good ways. Coolant level remains the same. Normal.
Old Nov 1, 2013 | 09:46 PM
Tofan's Avatar
Tofan
My truck definitely does the same thing, especially if I get on it in the morning. The white smoke you see is ASH coming out of the tailpipe. Think about it, the Filter does catch the black soot, but what about the actually AIR pressure? It still has to go somewhere. Hope this helps, also check your coolant like everybody said. Best of luck!
Old Nov 2, 2013 | 08:29 AM
darren32's Avatar
darren32
Cold is relative Paul
20130120_090513.mp4 Video by darren323232 | Photobucket
Old Nov 2, 2013 | 10:07 PM
ciscofreak's Avatar
ciscofreak
Thanks for the responses. Coolant level is good. Having been a 6.0 owner for a number of years, I get a little concerned with white smoke
Old Nov 2, 2013 | 10:20 PM
Double-Trouble's Avatar
Double-Trouble
The smoke may be normal but this paragraph is not.
Old Nov 3, 2013 | 01:42 AM
kper05's Avatar
kper05
True. There should not be a loss of power when close or during an active regeneration which begins at or after 2.66 usually.
Old Nov 3, 2013 | 09:20 PM
marchare011's Avatar
marchare011
A guy I work with bought a 2011 Chevy a couple years ago and it blew white smoke nonstop. Local dealer had it in the shop long time. GM finally bought it back if he would do another Duramax deal. He did and is all happy. He said it was something to do with DEF.
Old Nov 15, 2013 | 03:53 PM
ciscofreak's Avatar
ciscofreak
Update: The DPF is now at 25% load - inferred after a regen a few days ago. The DPF sensor voltage is at .50v if that means anything to the techs that may read this.
Old Nov 15, 2013 | 07:36 PM
Quadzilla's Avatar
Quadzilla
Even here in San Diego I get steam out of the exhaust on a "cold", humid morning.
(I'm originally from Seattle, so my definition of cold is very different than the SoCal natives. Down here, temps in the 40's is considered cold.)
Old Nov 15, 2013 | 07:42 PM
Hdslider's Avatar
Hdslider
Its Mr Bubbles Hard at work inside the exhaust.lmbo
