OIL LEAK!! HELP Pictures
Ok so I got the cooler fixed so its not leaking anymore. I cleaned everything up in the area it was leaking. Started the truck up and after a few min it started smoking so i crawled under it and watched it until I seen the oil. I swear it looks like its leaking out of the exhaust manifold studs. First and very last bolt on the drivers side. The smoke coming out is a mixture of white and blue. smells like oil though. While the truck was running and smoking i took a look back at the exhaust and while it was smoking there was a little bit of water dripping out too. Am I still looking at the head gasket? Is there some kind of temporary fix for it? Every mechanic looks at it for about 2 seconds and says well I bet its the head gasket. I dont want to bet 2 grand that its the gasket.
From everything you've observed and repaired you've not yet done a leak down test of the cooling system which should tell you almost immediately whether the head gaskets are the problem here.
There does come a time finding a trustworthy mechanic is the last and only option---without a proper diagnosis you might be at risk doing more damage.
I hope its not too severe but more and more its sounding like a blown head gasket.
frdf250
02-25-2010 08:38 PM
shortys07
09-20-2008 09:59 PM
