Edge vs Sct
Old Sep 19, 2011 | 08:28 PM
97ps's Avatar
97ps
SDBRONCS
Edge vs Sct
Have 07 F350 6.0 with custom tune loaded by Sct hand held programmer and installed Edge Insight for monitoring only but all internal engine parameters read too high. Called both Edge & Sct but each blames the other. Anyone else have this and found solution?
Old Sep 19, 2011 | 08:57 PM
npccpartsman's Avatar
npccpartsman
Not sure what you mean by internal engine parameters read too high. The SCT doesn't affect what the sensors read. The insight only reads what the sensors. Help us out with a little more detailed explanation as it sounds more like a wiring issue than a tuner/gauge issue.
Old Sep 19, 2011 | 10:51 PM
MPlayer's Avatar
MPlayer
When I first used my SCT my Edge did the same thing. I shut the truck off unplugged the Edge then plugged it back in and restarted the truck, went though the VIN stuff and it was fine after that. I haven't had it do it since. I think it does it if you first load your tune, have the truck running then plug the Edge in. I haven't tried to recreate it but that is kind of what happened when mine did it. Hope this helps.
Old Sep 29, 2011 | 08:47 PM
97ps's Avatar
97ps
SDBRONCS
Thanks I will try this and see if it works, I used to have a Banks PDA but it died on me and it was too expensive to replace just for a monitor since I replaced it with a custom tune with the sct
Old Oct 3, 2011 | 10:16 PM
97ps's Avatar
97ps
SDBRONCS
Thanks MPlayer, I did what you said and now the Edge reads properly, guess I had not turned the ignition off after installing the program with the SCT before plugging in the EDGE. All is well.
ndlawrence
Jun 17, 2013 12:22 PM
uuhiteboy
Feb 18, 2013 12:50 AM
dogdude2003
Sep 20, 2011 05:58 PM
lewis racing
Aug 19, 2010 06:04 PM
Baddfx4
Sep 6, 2007 01:13 PM
