time for some maintenance
Old Sep 19, 2011 | 09:32 AM
Ffemt10's Avatar
Ffemt10
So, I noticed my valve cover gaskets leak a little, few drops under the truck each day, I also noticed that my transmission is leaking....(zf-5) this bothers me as its leaking from a seal that is vertical in the middle of the trans.
questions to see if I can get some help here,
engine-I will be replacing the valve cover gaskets this weekend. Does anyone know the torque necessary for the bolts on the valve cover gaskets? can i get the covers off with minimal movement of things around the motor? Suggestions of things to look for/known issues? (oil change is due and was waiting for that before doing this)
trans-For the trans, the trans shifts well no clutch issues, what does ti cost to replace this kind of seal?
any and all help is appreciated!
Old Sep 19, 2011 | 09:53 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
valve covers are easy.
I did mine last fall. It will make things much easier if you remove the allternator from the engine. then remove the fuel filter and filter bracket. then jsut pop all the bolts out. some on the passenger side are a little hard to get to and see. as far as torque i think they are like ~10ft lbs. Just make sure you tighten them up evenly so you don't bend the cover and then have a permanent leak.
Old Sep 19, 2011 | 09:57 AM
Ffemt10's Avatar
Ffemt10
Thanks for the answer there, I will grab a tourque wrench this week(needed one for a long time). Anyone else that can confirm about 10lbs/sqft? When you say evenly should i do this in an circle following the outside of the valve cover or do this differently? Should I use any kind of sealant with the gasket?
Old Sep 19, 2011 | 10:00 AM
johnboggs21's Avatar
johnboggs21
I think the spec is between 7 and 10 ft lbs
Old Sep 19, 2011 | 10:01 AM
'94IDITurbo7.3
I did not use any other sealent with the gaskets and they are doing fine.
All i did when tightening was creep up on the final torque. i might have done the circle pattern around the cover like you say. pretty much you just don't want to tighten a couple bolts all the way down and not have any of the others tight at all, and then try to tighten those.
Kind of like doing head bolts, just no perticular pattern to follow here. tighten them up gradually.
Old Sep 19, 2011 | 10:27 AM
Ffemt10's Avatar
Ffemt10
thanks this was the answer i was looking for. Anyone have any ideas on what to do with that zf5?
Old Sep 19, 2011 | 10:28 AM
mrbison's Avatar
mrbison
You want to tighten them down kind of like how you tighten down lug nuts on a wheel - tighten across to the opposite side. If you tighten the covers down unevenly you can bend them and they won't seal right.
My $ 0.02 is that you won't need a torque wrench unless you want to buy one anyway. When I did mine, I just tightened them down so they were pretty sung and I haven't had any leaks. I doubt that you will be able to get the torque wrench in there anyway - some of the bolts don't have a lot of room for you to get at them.
Make sure that when you do the job to get all of the old gasket and sealant off of both surfaces before you try to install the new gasket and apply the new sealant. Use brake parts cleaner and a scraper to remove the old gunk.
Before you go out and buy stuff you might want to try and tighten down the bolts on the valve covers and see if that stops the leak. Sometimes you can snug 'em up a little and the leak will stop.
Old Sep 19, 2011 | 10:36 AM
'94IDITurbo7.3
I did the same thing as far as not using a torque wrench. mainly b/c i don't have one that small. My wrench is big. IIRC some of the bolts on the pass side need a open/box wrench to get tight.
Old Sep 19, 2011 | 11:08 AM
mrbison's Avatar
mrbison
I remember that too...
Old Sep 19, 2011 | 11:30 AM
Ffemt10's Avatar
Ffemt10
Ok i will try tightening those bolts tonight and see what happens. I plan on doing this on saturday, as it needs an oil change and the only time I have is that day. i do have plenty of wrenches, just no torque wrenches... Both sides are leaking pretty good so I may just change them in the interest of longevity.
Resendiz
Oct 18, 2016 08:56 PM
79F250inline
Oct 19, 2010 02:53 PM
yellow401
Mar 17, 2006 10:12 PM
canadianfordman
Aug 17, 2002 10:44 AM
matt68
Jan 10, 2002 09:25 PM
