Valve Cover Bolts?
Old Aug 16, 2002 | 05:14 PM
canadianfordman's Avatar
canadianfordman
Valve Cover Bolts?
How tight should aftermarket Valve Cover bolts be? I have heard that they shouldn't be tightened very tight but I don't want them to leak. What do you guys suggest, by the way its a 1984 351w. Thanks
Old Aug 16, 2002 | 05:36 PM
TorqueKing's Avatar
TorqueKing
Valve Cover Bolts?
10-15 ft*lbs, but no more. This is not very tight, if you don't have a Torque wrench to gage it by. Too much torque and it will warp the rails, so it won't seal right. err on the side of not enough torque, the valve cover shouldn't take much to seal it, usually the weight of the cover is enough to keep it from leaking. TK
Old Aug 16, 2002 | 07:16 PM
canadianfordman
Valve Cover Bolts?
Thanks for the help.
Old Aug 17, 2002 | 10:44 AM
MKPJ1's Avatar
MKPJ1
Valve Cover Bolts?
