Valve Cover
Old Jan 9, 2002 | 07:46 PM
matt68's Avatar
matt68
Valve Cover
How hard will it be to replace a valve cover gasket on a 82 300-6. thanks
Old Jan 9, 2002 | 08:02 PM
tetraruby's Avatar
tetraruby
Valve Cover
The job is quite easy. For starters buy the rubber gasket, not the cork one. It will last longer. You'll need to disconnect the fuel line, remove the air filer, PCV, and any other goodies running across the valve cover. Just make sure you hook them back up correctly. Clean the mating surfaces well. When you reinstall the cover install to 4-7 ft/lbs. (48 to 84 in/lbs) If you don't have a torque wrench use a socket driver to tighten the bolts - just remember not too tight!
Old Jan 10, 2002 | 07:00 PM
matt68's Avatar
matt68
Valve Cover
Ok thanks for the help. I got a torque wrench at the auto shop at school and that is were i am gonna do it. Thanks for the help.
Old Jan 10, 2002 | 07:43 PM
tetraruby's Avatar
tetraruby
Valve Cover
[updated:LAST EDITED ON 10-Jan-02 AT 08:45 PM (EST)]Remember that's inch/lbs. not ft./lbs. (ft./lbs. wrenches can't be set that low and be accurate)
Old Jan 10, 2002 | 09:25 PM
topo4u2's Avatar
topo4u2
Valve Cover
Ngemba
Aug 3, 2012 02:25 AM
00buck75
Mar 28, 2011 11:05 PM
MRStace84
Mar 16, 2005 11:40 PM
Quikirk
Mar 22, 2002 01:13 AM
deleontow
Dec 13, 2000 09:43 AM
