Gauge picks
Old Sep 19, 2011 | 09:17 PM
Galendor's Avatar
Galendor
Originally Posted by ctubutis
Here is what I did:
Wow, that's a real nice custom setup. Unfortunately it wouldn't work very easily for those of us with the optional "Human Passenger Seasonal Comfort Group" (e.g. heat/cooling vents):
Old Sep 19, 2011 | 09:23 PM
Gary Lewis's Avatar
Gary Lewis
Yep, same problem I have, which is why I really hope to get the factory gauges to work accurately and reliably.
Old Sep 19, 2011 | 09:55 PM
Galendor's Avatar
Galendor
Agreed. They are right there already, supplied by Ford for your monitoring use. Why shouldn't they be trusted? It never occurred to me that I couldn't trust the factory gauges until I started seeing it mentioned here. Is the same true for my Volvo wagon (another Ford). Should I doubt it's guages? One reason I trust my factory guages is that they seem to be consistent and vary depending on what I do to the engine. For example, my Temp guage usd to always read very low, the truck never warmed up. I found my thermostat was stuck open. Replaced with a 192 deg. T-stat, and temp now rises quickly stops right around "R" in NORMAL. Flushed cooling system and replaced water pump, now it stops right at "O" in NORMAL. These observations lead me to believe it may be actually functioning correctly.
Old Sep 19, 2011 | 10:45 PM
Gary Lewis's Avatar
Gary Lewis
Once I have the engine and tranny back in and a few minor details sorted I'm going to pursue the voltage regulator issue. I have noticed that temp and pressure change frequently, and together, so I'm sure the problem is the regulator. But, that was normal "back in the day" and is now easily fixed with solid-state regulators.
Then I'll put a few of the gauge units I have on the bench and test them awa several temp senders and pressure senders - maybe even new ones. I'd like to establish the resistance of each at a given temp/pressure awa what the gauges read at given resistances. Assuming I find consistency between senders and between gauges that should give us not only a good idea of what the gauges are telling us awa a way to check sending units.
But, don't hold your collective breaths, as I'm currently having too much fun holding 5 week old grandtwins to worry about the truck. However, all good things must come to an end, and we'll head home in a few days.
Old Sep 19, 2011 | 11:03 PM
Bagbyknoter's Avatar
Bagbyknoter
you should do something like this
Old Sep 20, 2011 | 06:37 AM
cadunkle's Avatar
cadunkle
Not a great picture, but you get the idea. I don't care for the tach location as I can't easily see it at a glance while driving. I'm trying to find a factory tach. In any event, I don't think there's a better place for gauges on these trucks to be clearly and easily visible but not in the way or awkward.
Old Sep 20, 2011 | 06:45 AM
jthorngate3's Avatar
jthorngate3
Those appear to be the 1 1/2" gauges you have there. Do they feel small at all, or are they easily enough visible? I also have the vents, but mine are connected to nothing as I do not have a/c. I think the gauges could still be easily implanted into those spaces with a minor custom panel.
Old Sep 20, 2011 | 06:54 AM
cadunkle's Avatar
cadunkle
They are a little small but I can easily read them at a glance and tell if something is not right. I went with the smaller gauges so I could fit the ones I wanted in the space available, and i'm happy with them.
If you want to do similar go junkyard or ebay hunting and get a non air conditioning dash panel... it will be easier and look nicer than patching up an air conditioning panel.
Old Sep 20, 2011 | 07:54 AM
Fordzilla80's Avatar
Fordzilla80
Surprised to see so many of you guys running just engine gauges and none for the transmission. Eventually I want to run trans temp gauges in both of my trucks, especially the Ranger, since complete trans rebuilds have become quite costly, especially for the electronically controlled automatic transmissions. It's just cheap assurance when you can see issues within the trans just by the temp it's running at.
Now obviously manual transmissions are a little simpler, so you guys don't necessarily need one unless you feel that your fluid is burning up.
Old Sep 20, 2011 | 12:17 PM
jthorngate3
It is extremely tough to find xls trim, so I figured on checking other locations for the gauges before going with that spot. I definitely plan on having a trans temp gauge in my truck
Old Sep 20, 2011 | 09:37 PM
Galendor's Avatar
Galendor
Hmmm - so the voltage regulator for the guages is weak or inconsistent - I did not know that. Well, that is a good reason for aftermarket gauges. Plus seeing the gauge values in real numbers would be nice. I guess I just originally shyed away from the idea because I didn't like the idea of putting More wires under my hood!
Old Sep 20, 2011 | 11:30 PM
BikeMaker's Avatar
BikeMaker
If you have the ability to relocate your stereo about 1/2" towards the floor, you can fit 3, 2-1/16" gauges above the stereo.
This was my original plan before I got carried away with it.......
Old Sep 20, 2011 | 11:34 PM
  #28
Gary Lewis's Avatar
Gary Lewis
Stereo? Out of my single speaker? Oh, you mean my radio!
Sorry, couldn't help myself.
Old Sep 21, 2011 | 01:19 AM
  #29
Galm_2's Avatar
Galm_2
Haha, I this was your truck at first
460 straight piped with 5" stacks - YouTube
Old Sep 21, 2011 | 07:14 AM
  #30
Grubbworm's Avatar
Grubbworm
I wish something like this could be done inside our stock factory gauge area, and look like it came stock from the factory. It would even be better if it could be done fairly simply without having to completely molest the stock factory dash. Oh well, wishful thinking.
AkF250HD
Aug 1, 2012 10:31 AM
Bullitt390
1983 - 2012 Ranger & B-Series
Jan 24, 2012 01:49 PM
Sparx Macgyver
26
Oct 18, 2010 09:57 PM
rcwoods
Electrical Systems/Wiring
Nov 14, 2003 05:46 PM
bdclark
1978 - 1996 Big Bronco
Jul 21, 2003 12:47 PM
