92 van motor removal
Old Nov 20, 2002 | 09:10 PM
tugboat's Avatar
tugboat
I have removed many truck and car motors in my life but i'm looking at pulling a 351W out of a 92 conversion van... what is different from a van and a truck and what problems will i run into. THAnks in advanced
Old Nov 20, 2002 | 11:06 PM
mickey1's Avatar
mickey1
I'm not sure if I'll be much help but I pulled a 351 out of my 86' E250 a few years ago. The best thing about Ford vans is that they come out the front. It's a pain to remove so much stuff but it makes the job a breeze. Take off the grill and front bumper along with the radiator and top bracket. You can see the whole motor and work on it.
You will need an engine crane instead of a hoist. Because of the angle of the crane, mine was easier to pull out after putting the truck up on cement blocks. The first time I did it, I left the C6 attached. The second time I took off the C6 first. Good luck.
Old Nov 21, 2002 | 05:20 AM
tugboat's Avatar
tugboat
What is the difference in an engine hoist and an engine crane??
Old Nov 21, 2002 | 06:35 PM
edenroadmaster's Avatar
edenroadmaster
Old Nov 21, 2002 | 10:38 PM
mickey1's Avatar
mickey1
To me, an engine hoist hangs from an "A" frame or some other overhead
beam whereas the engine crane has a hydraulic jack which lifts an adjustable arm up and down and is also on wheels.
dudef150
Nov 28, 2014 08:48 AM
kynnhoj
Aug 11, 2012 10:26 AM
wrench11
Engine Swaps
Jun 4, 2010 07:42 PM
bengen
Apr 13, 2006 08:06 PM
92Flare150
May 23, 2004 10:19 AM
