Switching Motors?
Old Nov 27, 2014 | 07:52 AM
dudef150's Avatar
dudef150
Switching Motors?
I need to replace the motor in my 93 F250 its a 5.8(351) ....I have access to a 5.8 out of a 93 E250 van...my truck is four wheel drive the van is not....so the question is what changes if any will have to make to make the motor out of the van work in the truck thanks
Old Nov 27, 2014 | 07:56 AM
LeoJr's Avatar
LeoJr
Are they both auto trans? I put a donor 5.0 from a manual into a F150 auto and found that the crank was not machined to fully accept the auto. Caused much mystery and frustration.
I'm sure someone with better info will be along soon...
Old Nov 27, 2014 | 08:11 AM
dudef150's Avatar
dudef150
yes they both have the E40D transmission the one in my truck was just rebuilt less than 200 miles ago
Old Nov 27, 2014 | 09:38 AM
wtroger's Avatar
wtroger
Should be a bolt up no mods needed. You will have to use the 4wd tranny.
Old Nov 27, 2014 | 09:47 AM
wtroger's Avatar
wtroger
Leojr the only thing you should have had to do to make a standard trans motor work in front of an auto trans was remove the pilot bearing. I have seen cranks not machined for pilot bearings but hose where GM cranks
Old Nov 28, 2014 | 07:53 AM
LeoJr's Avatar
LeoJr
wtroger, thanks for dudef150 in the right direction!
The 5.0 that came out of my Dad's '87 with a manual was the donor engine that I was mating to my '92 auto trans.
The different depths of the crank was a complete surprise. But when the trans was tightened to the engine the starter couldn't budge the crankshaft. After a small amount of the trans shaft removed it fit fine.
I'll never assume manual and auto cranks are the same again.
Old Nov 28, 2014 | 08:48 AM
Island Time's Avatar
Island Time
Of topic, but, did you reuse the manual starter? The nose is different between a starter for the manual and auto. I can't remember which way, but if you use the wrong starter it won't work properly.
Lilbrowntruck
Jan 12, 2017 07:56 AM
Rat77
Apr 20, 2012 07:28 PM
97stroker-kt
Dec 21, 2008 11:19 PM
SearchingBearCub
Aerostar
15
Apr 22, 2006 12:18 PM
mlaser
Nov 10, 2004 09:38 AM
