85 302 block for 92
Old May 18, 2004 | 06:18 AM
92Flare150's Avatar
92Flare150
85 302 block for 92
I have 230,000 miles on my 302, 92 F150 Flareside, and have an 85 E150 van with a 302 with 144,000. I am using the van for parts for my 78 E350 RV and plan to use the engine for my F150. I will be rebuilding the motor over time and would like to know if the EFI stuff on my 92 will bolt up to the 85. THIA
Eric
Old May 21, 2004 | 06:07 AM
92Flare150's Avatar
92Flare150
Anyone???
Old May 21, 2004 | 08:21 AM
jwtaylor's Avatar
jwtaylor
man you expected a reply in 11 minutes thats ambitious, j/k.
Yeah it will bolt right over, be sure to use the 92 engines timing cover/ water pump and accessories/brackets and it will be an otherwise direct swap.
Old May 21, 2004 | 09:03 PM
92Flare150's Avatar
92Flare150
Thanks, jwtaylor.
I actually posted on the 18th and no reply. So I just bumped it today. I really appreciate the reply.
Eric
Old May 22, 2004 | 06:25 AM
jwtaylor's Avatar
jwtaylor
Ouch, I see that now, I didn't see your post before for some reason or I would have replied, I hate it when a post goes unanswered. Later
Old May 23, 2004 | 10:19 AM
daerhldgs2's Avatar
daerhldgs2
Water pump ,timing cover only real problems , no knock sensor location which is no real problem ,I've made this swap it's a bolt in.
FORD E-150
Jul 18, 2009 10:36 AM
f150flrsd
15
Jan 29, 2009 08:09 AM
dhag911
Jul 18, 2006 06:08 PM
