e4od not downshifting????
Old Sep 18, 2011 | 11:45 AM
coalmanjhj's Avatar
coalmanjhj
I have a 1993 f-150 with a 6 cylinder gas engine and an e4od tranny. When you first pull out it will pull out in first but shifts hard into second and drive. Overdrive seems to come in just fine. If im just going through town and hit 2nd gear it will not downshift even at a complete stop. On the highway it will go back to drive but no farther at a complete stop. However you can shift into reverse and back to od and it will pull out in first and go through all the gears. But once you stop it will not go down past drive unless you shift to reverse and then back to od. i have not tried just going to neutral then to od but i will try that also and see what happens. Any info would be greatly appreciated.
Old Sep 18, 2011 | 12:25 PM
White 97 xlt's Avatar
White 97 xlt
E4OD is completely computer controlled, have you pulled the DTC codes? Does the speedometer work properly?
Old Sep 18, 2011 | 01:12 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » How To Run a Self-Test Here is a link on how to get any codes as White suggests.
Old Sep 18, 2011 | 07:32 PM
coalmanjhj's Avatar
coalmanjhj
have not had codes pulled yet. the speedo does work right. also thanx for the link for how to read the codes. will try this tomorrow and let u know how it goes.
Zapp911
Oct 11, 2022 03:32 PM
Levicoffey5
Jan 11, 2019 08:16 AM
harland64
Aug 9, 2016 08:33 AM
bfwill
1978 - 1996 Big Bronco
Sep 13, 2009 11:38 AM
JCATC
Apr 8, 2004 07:15 AM
