funky shiftin e4od
Old Aug 4, 2016 | 08:49 PM
harland64's Avatar
harland64
funky shiftin e4od
i have a 92 f350 with er0d sometimes it couldn't work better other times when it gets to 3rd itll rev really high go into gear then come back out repeatable then sometimes itll hangup in gears and ill have to manually shift 1-2-3. when it first did it it was only in third was told bad tranny had it built and no better. the tranny shop told me it mit be a tps and no better. what do yall think? I seen where the mlps mit do it
Old Aug 4, 2016 | 09:26 PM
Lead Head's Avatar
Lead Head
First step is to check and pull any trouble codes. Does your speedometer work well, or does the needle jump around sometimes?
Old Aug 4, 2016 | 09:33 PM
harland64's Avatar
harland64
Had no codes the other day and speedo works correctly
Old Aug 5, 2016 | 08:25 AM
Lead Head's Avatar
Lead Head
No codes at all? At the minimum you should get 11 or 111
Old Aug 8, 2016 | 03:54 PM
harland64's Avatar
harland64
Just checked the codes again at work only thing I'm getting is 33 an 15
Egr is blocked and gonna check in a little while to see if there is power to the PCM
Old Aug 8, 2016 | 10:30 PM
Lead Head's Avatar
Lead Head
Pins 1, 37 and 57 should get power with the key on. Pin 1 should get power all the time. Code 15 can be set if you recently disconnected the battery. If pin 1 has power, and you haven't recently disconnected the battery, than I would suspect PCM failure.
Old Aug 9, 2016 | 08:33 AM
thehead406's Avatar
thehead406
I had a shifting issue but the limp mode problem. Never did find out specifically but I checked out all the electrical connections that have anything to do with the trans. From the vss in the rear axle to pulling nd inspecting the psom from behind the speedometer. Did something right because haven't had a problem since. (Knock on wood)
1979kent
Dec 27, 2011 01:09 AM
coalmanjhj
Sep 18, 2011 07:32 PM
jeff9942
Nov 6, 2009 08:37 PM
JCATC
Apr 8, 2004 07:15 AM
GWTarpon
Feb 7, 2004 11:07 AM
