Edge CTS
Old Sep 17, 2011 | 09:40 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Originally Posted by JonArmy
Has anyone used the Edge CTS?
My apologies for the highjack.
Sean
Old Sep 17, 2011 | 09:59 PM
JonArmy's Avatar
JonArmy
No problem, of course right now I'm using the SGII, and I use some of the codes. I'll keep the SGII, once I get the CTS I found a OBDII spliter that I will use
Old Sep 17, 2011 | 10:01 PM
amdriven2liv
Cool, would like to see how you mount everything with the splitter. Mind sharing where you found your splitter and price?
Old Sep 17, 2011 | 10:25 PM
JonArmy's Avatar
JonArmy
Amazon.com: Cable, J1962M to 2-J1962F, Splitter Cable, 1ft (145802): Automotive
Cost only around $22.95, of course by what I've read with a splitter, you can't really promise anything, but of course if you read other PID you should be fine, but it sounds like trying to read on PID on two devices it could have problems.
Old Sep 17, 2011 | 11:59 PM
BLADE35's Avatar
BLADE35
Originally Posted by amdriven2liv
They are Xgauge codes. Wonder if Edge is now using these codes. Linear Logic might like to know.
(I wrote that list)
so you edge guys can use these X codes too???
Old Sep 18, 2011 | 12:34 AM
t4m4m4's Avatar
t4m4m4
Excellent quality product very easy to install and use. It is easy to attach an OBD Scanner / Diagnostic for all car's running parameters.
Old Sep 18, 2011 | 07:57 AM
Jigger2020's Avatar
Jigger2020
Thanks to everyone here for the info to help Jonarrmy & I, Gigger
Old Nov 21, 2011 | 09:27 PM
Superdutyintendent's Avatar
Superdutyintendent
I have an obd2 splitter that I am trying to use for both an edge insight and a scangauge but I haven't been able to get it to work, either one or both shut off shortly after start up, any suggestions?
Old Nov 21, 2011 | 11:27 PM
Dieselpop's Avatar
Dieselpop
My understanding of how this works is they have to be the same 2 ScanGauge or 2 Edge Insights this is what i read about 6 months ago so i have the older Edge and will be getting the Edge CTS next year but i am going to call Edge first before i send the $$$. I would like to have the ScanGaugeII less $$$ and a great tool.
pop
Erik727
Apr 19, 2012 09:02 PM
Gmangh15
Nov 16, 2011 09:11 AM
j-bar
Oct 18, 2011 05:01 AM
TomCat-F350
Oct 2, 2011 11:58 AM
amdriven2liv
Mar 28, 2011 08:59 PM
