Fuel Pressure Check
Old Sep 17, 2011 | 10:22 AM
ronjon95's Avatar
ronjon95
Fuel Pressure Check
Trying to find the info on which plug to remove for Fuel pressure check. I think one is after the filter and one is before the filter. I read it some time ago, I tried searching for it but it will take all day.
Thanks Ron
Old Sep 17, 2011 | 10:48 AM
snakedoc's Avatar
snakedoc
the lower one is after the filter.
top it before filter.
Old Sep 17, 2011 | 11:15 AM
ronjon95's Avatar
ronjon95
Great Thanks!! Will be back with results shortly. Should I check it before and after??
Old Sep 17, 2011 | 12:12 PM
Franko72's Avatar
Franko72
Molon Labe
Unless your filter is really dirty, the pressures should be the same.
Old Sep 17, 2011 | 12:14 PM
ronjon95's Avatar
ronjon95
Just changed the Filter about a Month ago.
Old Sep 17, 2011 | 12:18 PM
Franko72's Avatar
Franko72
Molon Labe
prob wont matter then. when I installed my fuel pressure gauge a few weeks ago, I tried both ports with a filter that had 15k on it. There was no difference in pressure between the two ports.
Matter of fact, it didn't change after I put a new filter in either.
Old Sep 17, 2011 | 01:35 PM
ronjon95's Avatar
ronjon95
Back with results!!
Idle 69-70 PSI even after warm up and ran down the road!
Driving on 100 hp position TS Chip dropped to 62 at full throttle for about 5 Seconds. Then back up to 69 -70 PSI.
I have the FPR mod with the lowest pressure spring installed. This is higher than what the spring pressures ratings are or is the ratings under driving conditions?
Old Sep 17, 2011 | 02:09 PM
woodnthings's Avatar
woodnthings
Every truck will be different. The machining on the FPR will also have some effect on it too. Those numbers are close to what I see including the pressure drop.
Old Sep 17, 2011 | 02:38 PM
snakedoc's Avatar
snakedoc
looks good to me.
JOHNSHO
Oct 11, 2011 05:56 PM
granny_rocket
Apr 7, 2010 11:27 PM
Fair 96
Sep 28, 2009 05:19 PM
jeffcojason
Modular V10 (6.8l)
Mar 2, 2004 06:58 PM
xpaulx
1983 - 2012 Ranger & B-Series
Aug 19, 2002 10:29 PM
