FPR shimming
Old Apr 7, 2010 | 09:44 PM
granny_rocket's Avatar
granny_rocket
FPR shimming
SO i decided to finally shim the FPR today. Went and bought 100 bb's (3/16", and i could only buy them in bulk, so i have extras if anyone wants one or two).
I checked pressure pre-op. 60-65 PSI. Put the ball in behind the spring and checked pressure. Still 60-65 PSI. WTF???
What does the fuel filter have to do with the pressure reading? The reason I asked is because I put a cheapy autozone filter in a few weeks back (i know, i know, I need to get a NAPA gold) and heard rumors that the aftermarket filters don't press open the fuel fill the way the stock does. SO that being said, does the filter come before or after the pressure regulator? Could the crappy filter be causing the problem regardless?
At my whits end... was hoping to see an increase in power. Boo to that!
Any help is much appreciated.
Al
Old Apr 7, 2010 | 10:28 PM
Talyn's Avatar
Talyn
Press what huh?
You can run the bowl without the filter as far as I know.
Did you check your fuel pressure before and after?
Old Apr 7, 2010 | 10:40 PM
granny_rocket
Originally Posted by Talyn
Press what huh?
the shaft that comes out of the center of the fuel bowl notice the filter has a hole in it) is the fuel inlet if I am correct. In the lid/cover that screws on, there is a dimple/nipple that opens a valve in that shaft. If aftermarkets aren't exact to the factory lid, then it might not open all the way restricting fuel flow. At least this was my understanding to it.
I did check pressure before and after. It was 60-65 both times. ????
Old Apr 7, 2010 | 10:44 PM
Talyn's Avatar
Talyn
65 is good. Sounds like something didn't go right with the mod though.
You have to make sure that the spring when you put the cap back on gets into that nipple otherwise you'll not gain any fuel pressure and could possibly lose some.
I don't know anything about the fuel filter deal your talking about, because there is nothing like that on my filter, but mines a 94, my fuel bowl is different.
I don't see why they would set it up like that.
Old Apr 7, 2010 | 11:13 PM
granny_rocket
yeah, i thought 65 was good considering 75 is the max pressure you'd want to see. IDK. i'm lost... ANYONE ELSE???
As far as the filter housing/fuel bow goes i don't know what differences are there between a 94 and 96 but mine is similar to this stolen image I got from google image search:
The black shaft in the center is what Im talking about with having a valve that needs to be opened.
Old Apr 7, 2010 | 11:27 PM
cowmilker08's Avatar
cowmilker08
That shouldn't affect it.
Pressure in the fuel bowl it only 7-10 psi.
Fuel Tank => Diaphram side of fuel pump => pumped to approx. 7-10psi => Through filter/bowl => Back to fuel pump (piston side???) => pumped up to pressure determined by FPR => Injectors => excess fuel to FPR => returned to fuel tank.
I don't see why the filter would cause a failed mod, unless against all odds it is restricting flow just the right amount that the piston side of the pump only gets enough fuel to pump up 65 psi. Yeah, HIGHLY unlikely.
I don't think the screen between the FPR and the fuel bowl would cause this senerio but i'd check to see if its clogged.
I'd suggest taking the mod apart and retesting stock.
Your gauge doesn't max at 65 psi, right? lol, some of the simplest things are overlooked.
jhobbs26
Jan 8, 2024 12:59 PM
BadDogKuzz
Mar 23, 2016 01:15 PM
Diesel Submariner
39
Aug 7, 2015 01:11 PM
crzycrazycarl
Apr 8, 2010 09:52 AM
Hussler
Feb 22, 2008 08:23 PM
