rear diff oil change
Old Sep 17, 2011 | 01:41 PM
renoduckman's Avatar
renoduckman
I know this has been talked about before. But when do you guys like to change your rear diff oil? I dont see it in my owners manuel. I have a standard diff, not the limited slip. Joe
Old Sep 17, 2011 | 02:07 PM
woodnthings's Avatar
woodnthings
Usually around a 100k. I changed mine at 60k, but I use mine to tow mostly.
Old Sep 17, 2011 | 02:18 PM
clintbonnie's Avatar
clintbonnie
According to my owners manual, maintenance guide, and I quote:
"Rear axles containing synthetic lubricant and light duty trucks equipped with Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected or if axle assembly has been submerged in water.. Non-synthetic rear axle lubricants should be replaced every 3,000 miles.."
If you don't have a copy, go to:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Sep 17, 2011 | 02:34 PM
RainStroked's Avatar
RainStroked
I wouldn't follow what the owner's manual says in this case, I change mine every 40-50k or so.
Old Sep 17, 2011 | 03:49 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I first changed mine around 140k and am coming due again in a couple of thousand miles. For sure I will change again before 300k. It is about 10th or 12th place down on the "PSD List"
Synthetic gear oil is amazing stuff...
Bigdflyer
Sep 28, 2018 10:58 AM
TheACN
Jan 22, 2013 10:09 PM
BeBo03
Apr 26, 2008 10:43 AM
zomowiec
Sep 23, 2006 06:26 PM
jake98
Jan 31, 2005 09:50 PM
