Engine Oil Temps
Old Sep 16, 2011 | 05:45 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Question Engine Oil Temps
after doing some data logging... I have notice my EOT never goes below 105 (F) degrees, even after the truck has been parked for 2 days.
is this normal? do I need replace the EOT sensor? what else might cause this?
Old Sep 16, 2011 | 06:24 PM
cheezit's Avatar
cheezit
ohm out the sender
Old Sep 16, 2011 | 06:28 PM
96_F250_Deezal
ok... what should the readings be?
Old Sep 16, 2011 | 08:59 PM
motocaptain's Avatar
motocaptain
Temp
After sitting for a couple days temps eot and ect should be ambient air temp.
Old Sep 16, 2011 | 10:23 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
+1 ^^^^ Agree.
Old Sep 17, 2011 | 09:21 AM
96_F250_Deezal
I understand what the temp readings should be.
my response was to cheezit... he recommended I "ohm out" the EOT sensor, which is good advice. my question is when I take ohm readings on the sensor, what should the resistance readings look like?
I am fairly certain the EOT sensor is bad, but I want make sure there is nothing else that might cause the inaccurate readings before I replace the sensor.
Old Sep 17, 2011 | 02:47 PM
motocaptain
Ya I kinda caught on after I posted, good luck. If it's not close to ambient and the ect is after sitting I would just replace the sender..
Old Sep 17, 2011 | 02:52 PM
96_F250_Deezal
drove the truck to work.. its been sitting about 5 hrs now. EOT sensor "ohms" out at 19.5 ohms with the meter on the "K" range.
I am guessing that's a little high
Old Sep 17, 2011 | 04:07 PM
cheezit's Avatar
cheezit
see heres the thing the sensor is a thermister so with out knowing what the temp is out side when the check is done noone can give you the correct awnser as to what the correct value should be.
however that information should be in section 6 of the pc/ed
Old Sep 17, 2011 | 04:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's a voltage test you could try:
http://fordfuelinjection.com/?p=28
Old Sep 17, 2011 | 04:29 PM
Lou Braun's Avatar
Lou Braun
Following Cheesit's tip, there is a temperature vs resistance chart buried in the service manual.
50 deg - 59,016 ohms
77 deg - 30,000 ohms
86 deg - 24,329 ohms
95 deg - 19,696 ohms
140 deg - 7,556 ohms
If you are getting a number like 19.5K (19,500 ohms), that corresponds to a termperature of 95 degrees.
I'd look at coolant temperature and intake air temperatures after sitting overnight and compare them to EOT. They should be very close to each other. The spec buried in the manual is 10 deg F.
Lou Braun
Old Sep 17, 2011 | 04:53 PM
william_04_x's Avatar
william_04_x
You can use your ECT sensor for a reference. The EOT and ECT sensors should Ohm out the same when the engine is cold.
Old Sep 17, 2011 | 05:29 PM
96_F250_Deezal
Lou Braun
with the scan tool hooked up, outside temp was roughly 65 (F) degrees. engine coolant temp was 68 degrees and Intake air temp was 70 degrees. The Engine Oil Temp was 105 degrees
Old Sep 17, 2011 | 05:32 PM
96_F250_Deezal
I think its fair to assume the EOT sender is fuxored
Kdawg89
Jan 20, 2016 11:33 AM
busdriver47
Jan 3, 2013 02:38 PM
AZwhite350
Mar 11, 2012 11:47 AM
twg1966
Jun 12, 2006 05:13 PM
ehumaui
Oct 17, 2003 07:52 PM
