Scanguage ?
Old Jan 3, 2013 | 06:01 AM
busdriver47's Avatar
busdriver47
Question Scanguage ?
Should the oil & water temp be the same when the engine is cold? My oil temp is about 2 degrees higher.
Old Jan 3, 2013 | 06:06 AM
npccpartsman's Avatar
npccpartsman
That's perfectly acceptable. Your sensors won't be perfect. They all have some margin of error "built in". Each sensor could be one degree off and give you a 2 degree margin of error and that's absolutely nothing. It could also depend on how long the engine sat unused.
Old Jan 3, 2013 | 07:07 AM
Craig.Parks's Avatar
Craig.Parks
My oil is 2 degrees higher also.
Old Jan 3, 2013 | 10:00 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
As is mine..... I've been toying with the idea of swapping the sensors.....and leaving them that way. Just LOOKS better! LOL
Old Jan 3, 2013 | 02:29 PM
Misky6.0's Avatar
Misky6.0
Not sure this helps or makes it worse...
Keep in mind the temperatures are rounded...
61.4 might round to 61
62.6 might round to 63 when in fact they are only 1 degree off.
I think one reads < 100 with a decimal, while one doesn't.
The digital display is providing info from an analog device.
one, two, or three degress is all "close enough" - in the AM.
Old Jan 3, 2013 | 02:38 PM
busdriver47
Smile
Thank's that is what I thought.
Ford are best
May 6, 2013 08:16 AM
phantomphixer
Apr 5, 2012 06:36 PM
96_F250_Deezal
Sep 17, 2011 05:32 PM
BPofMD
Apr 17, 2006 02:52 PM
BrianA
Oil & Lubrication
Mar 25, 2003 09:51 AM
