wont start
Old Sep 16, 2011 | 04:42 PM
2000F250guy's Avatar
2000F250guy
wont start
2000 F250 6 speed 180K
I just got the truck back from ford after they installed a PCM and IDM
I drove the truck home, it ran good.
Today i go to start it up, I notice the "Wait to start" dont light up. i wait a few sec turns over just fine but wont start/fire.
I also notice the "check Engine" light doesnt come on either when have just the key turned over.
FYI the return hose on the over flow was broken and sprayed under the hood on the passenger side of the truck. I forgot it was broken.
any ideas on what i should check?
Old Sep 16, 2011 | 04:57 PM
snakedoc's Avatar
snakedoc
the fuse that runs the pcm could be blown. i think number 30.
Old Sep 16, 2011 | 04:58 PM
carltonwebb's Avatar
carltonwebb
It could just be bad timing and the fuel bowl heater went bad.
Check fuse 19 I think in the fuse box under the hood. It is one of the large maxi fuses. There are not that many. If it is blown, unplug the fuel heater on the fuel filter housing. You can take the one out of the trailer tow battery charge to get it to the store to get it going if you need to.
Old Sep 16, 2011 | 05:00 PM
2000F250guy
the bowl heater would make the " wait to start" not illuminate?
snakedoc's Avatar
snakedoc
i cant remember the number it changes on some of the years.
snakedoc's Avatar
snakedoc
yes the pcm has no power to tell it to come on
Old Sep 16, 2011 | 05:06 PM
carltonwebb
Fuel bowl heater is on same circuit as the pcm. When fuse goes, pcm does not power fuel pump, wts light etc. so the starter will turn but has no power from ecm.
Old Sep 18, 2011 | 02:11 PM
2000F250guy
it was the Number 30 fuese that controls the PCM/Idm 30A, some one placed a 5A fuese in it. Some how when checking it i missed it. Thanks for the info.
bobbyt89
Jul 30, 2011 09:43 AM
metalshaper
15
Dec 15, 2009 09:15 PM
bigfordandjeep
15
Apr 6, 2009 09:18 PM
bens99f350
Jan 29, 2009 03:30 PM
JAX
Jan 23, 2003 08:53 AM
