truck wont start
Old Nov 9, 2009 | 04:24 PM
metalshaper's Avatar
metalshaper
truck wont start
I have a 2000 F-350 with 74,000 miles,I came home from work parked it in driveway and a few days later [today] it wont start.There is no wait to start light coming on and the service engine soon is on,is there a way to check the code without a scanner?I have a DP-tuner as well.
Old Nov 9, 2009 | 04:44 PM
Action4478's Avatar
Action4478
Check the fuse for the fuel heater ,If it s blown , you may need to unplug the heater , I think its #30 under the hood ..Not good having the CEL on too ...
Old Nov 9, 2009 | 08:04 PM
metalshaper
I forgot to say that the engine will crank.
Old Nov 9, 2009 | 08:09 PM
F350-6's Avatar
F350-6
Like Rick said, check fuse #30 in your truck. If it's blown, unplug the fuel bowl heater, replace the fuse, and the truck should start right up.
No WTS light means the PCM isn't getting the voltage needed to make the injectors and fuel delivery circuit work. The starter sill works fine so the engine will spin, but no start and no smoke out the tailpipe while cranking.
How does fuse #30 look?
Old Nov 10, 2009 | 07:43 AM
metalshaper
Ok I checked fuse 30 and it is ok.Maybe the DP-tuner is coming loose,but the display is lighting up fine.I will check that to just eliminate that ,anything else I need to check?
Old Nov 10, 2009 | 07:49 AM
riverrat41's Avatar
riverrat41
Remember not to mess with the chip with the key in the ignition.
Old Nov 10, 2009 | 08:09 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Would the #30 fuse be under the dash instead of under the hood?
Old Nov 10, 2009 | 09:39 AM
rbaker6336's Avatar
rbaker6336
Yes it is under dash.#30 under hood is PCM relay
Old Nov 11, 2009 | 05:43 PM
metalshaper
Problem solved ,I will post the fix at a later date .Thanks for your help,it give me a place to start looking for the problem.
Old Nov 11, 2009 | 05:46 PM
Dave Tyler's Avatar
Dave Tyler
What fixed it?
If you solved the problem, how about what fixed it? I am having similar problem and mine is not fixed. Dave Tyler
Old Nov 11, 2009 | 06:39 PM
metalshaper
Dave send me a email. metalshaper@live.com I will respond with the fix.
Old Nov 11, 2009 | 07:04 PM
F350-6's Avatar
F350-6
How about just telling all of us? Including all the guys here that were trying to help you?
Old Nov 11, 2009 | 08:39 PM
megawatt00's Avatar
megawatt00
Agreed................
Old Nov 11, 2009 | 10:27 PM
lhud's Avatar
lhud
I also agree with the two previous posts!
I just finished experiencing a similar problem and at this moment there are others with a crank/no start conditions with their trucks.
Solutions to other similar fixes are crucial to helping others in solving these problems.
Old Nov 12, 2009 | 09:38 PM
metalshaper
I also agree with you,but I feel the need to protect the good reputation of others untill I get a chance to talk to them and make absolutely sure that is where the problem is and I did not over look something simple,but for now my truck is starting and running like it should.
