How does the Engine bay light work?
Old Sep 15, 2011 | 11:00 PM
EL_Musico's Avatar
EL_Musico
I just put in a new bulb in the engine bay light socket (my truck didn't have a bulb in the socket). After jiggling the cable a bit I got it to turn on with the truck off (no lights, no keys in ignition). I partially closed the hood and can see the light turn off just before it shuts closed. How does it do that? I traced the cable back to the terminal and there doesn't seem to be a switch like on the doors. Am I missing something?
Old Sep 15, 2011 | 11:14 PM
elgemcdlf's Avatar
elgemcdlf
It is a mercury switch. When you open the hood it runs to one end completing the circuit (well it triggers the connection). Hood down and the mercury moves to center making it not heavy enough over the contacts to maintain connection. It is built into where you put the bulb (usually).
Old Sep 15, 2011 | 11:19 PM
EL_Musico's Avatar
EL_Musico
Get out of here! Really? I've never heard of that. I wonder if it's prone to failure in older trucks. i.e. turning on at night and therefore drains the battery. Maybe that's why there was no bulb in there...do you have a bulb in yours?
Old Sep 16, 2011 | 05:05 AM
jowilker's Avatar
jowilker
You can install a toggle switch inline if you are concerned about it coming on when not needed. The mercury switch is what your older house thermostat used to operate.
John
Old Sep 16, 2011 | 11:04 AM
elgemcdlf's Avatar
elgemcdlf
I don't have anything under my hood. Came that way when I bought it and doesn't really matter to me. I do have an operational underhood light in my '90. As to going out on older trucks. Let's think about that for a minute. Truck is 40 years old. Assuming switch is original to the truck I would assume it gong bad to be highly likely. After all it is 40 years old. They are cheap.
Old Sep 16, 2011 | 11:42 PM
HIO Silver's Avatar
HIO Silver
The socket may not have had a bulb installed cuz a previous owner found out the hard way that the light can turn on and kill the battery if it's parked on a slope.
90s F-Series and Broncos have under hood lights... cheap from the JY and a nice lil detail. Get two of 'em, one for each side of the engine bay. Additional sets are good for footwell lights.. I'm not a fan of the single dome lights.
Old Sep 17, 2011 | 10:30 AM
EL_Musico's Avatar
EL_Musico
Good tip. DIdn't think about sloped parking. I'm in the SF bay area, lots of hills here.
Old Sep 17, 2011 | 03:37 PM
jowilker's Avatar
jowilker
HIO, Not sure about 2 of them, the one in my 86 has like a 25 ft. cord on it. The light can be pulled to the rear of the truck.
John
Old Sep 17, 2011 | 03:38 PM
elgemcdlf's Avatar
elgemcdlf
Just park nose downhill
Old Sep 17, 2011 | 08:21 PM
EL_Musico's Avatar
EL_Musico
Got it.
Old Sep 18, 2011 | 10:08 AM
HIO Silver's Avatar
HIO Silver
Lemme clarify.. each 90s truck I referred to has one underhood light. Therefore, two donors are needed.
Is that 25-foot cord a factory part? I gotta look for one if it is!
As a matter of convenience, it can be a PITA cuz sometimes ya just wanna pull in and get out. Personally, my driveway is nearly 18 percent slope and I hate backing up a hill.
Old Sep 18, 2011 | 10:43 AM
elgemcdlf's Avatar
elgemcdlf
I had a truck with all the wire as well. The end of the light assembly turned 1/4 turn or so and the end came out with a "cord" so you could move it around. These are usually big plastic lights. Mine was also in a F series truck but don't remember what year.
Old Sep 18, 2011 | 05:16 PM
jowilker's Avatar
jowilker
I can only presume that it is, 2nd one that I have seen. Don't know for sure the length of the cord, Bill should have that info.
John
Old Sep 18, 2011 | 05:42 PM
go_racing84's Avatar
go_racing84
You can find the same sort of switch in many (most?) trunk lights and older (non-digital) home wall thermostats.
Jack118711
19
Jun 5, 2019 10:49 PM
440 sixpack
May 17, 2019 08:11 AM
joegeds
Jun 18, 2014 06:52 PM
Iron Gorillas
Sep 16, 2012 07:23 PM
Plain Jane
Feb 9, 2012 09:16 PM
