Sputtering X
Old Sep 19, 2011 | 10:23 AM
  #31
BAJI26's Avatar
BAJI26
Question
Is there any quality difference between the non-Motorcraft and Motorcraft COPs?
I've found these:
Duralast/Ignition Coil (C1417) | AutoZone.com
Which one is better they have different Resistance Specs?
Napa | Balkamp | Part Number: BK 3009298
Also:
NEW DRAGON FIRE PERFORMANCE IGNITION COIL ON PLUG COP
NEW Ford Ignition Coils On Plug COP Pack 8 TRE-IC-8058
NEW IGNITION COIL ON PLUG COP **FITS ALL FORD V10 DG508
Old Sep 19, 2011 | 11:31 AM
  #32
rlh68050's Avatar
rlh68050
I've found these:
Also:
Duralast = Auto Zone discount brand = junk.
Please use the Motorcraft brand. There are many posts on these boards where someone has used an aftermarket brand coil only to have it fail quickly. The OE Motorcraft's last > 80k plus miles (at least this is my experience) so why would you want to install a cheaper brand? Look on eBay for some deals.
Old Sep 19, 2011 | 02:51 PM
  #33
EXv10's Avatar
EXv10
All mine have gone 150k miles so far.
Old Sep 19, 2011 | 03:36 PM
  #34
rlh68050's Avatar
rlh68050
I had two go at around 80k and after the second one I decided to change them all out. Did the plugs then too as your 1/2 way there with the R&R of the COP's
Old Sep 19, 2011 | 06:51 PM
  #35
BAJI26's Avatar
BAJI26
Well money is the issue now, I'll just buy one Motorcraft and see if I can locate the culprit!
Old Sep 19, 2011 | 09:41 PM
  #36
EXv10's Avatar
EXv10
There's a couple used ones on ebay right now. If I had all the money everyone has needlessly spent on cops in the last ten years in the USA I would be rich. Actually he had 8 of them today and they were cheap.
Old Sep 20, 2011 | 12:08 PM
  #37
EpikExcursion's Avatar
EpikExcursion
Is the truck only doing it when u first start it or when its idleing??? Does it do it while u are driving or accelerating at all? I would lean more towards clogged EGR or u may take it to a deisel shop in your area and have them hook it up to their computers...check all your injectors to see how they are looking, may have one dead or overfueling..never know. Coil is obviously the cheapest route but if its misfiring while u are driving my bet would be the ladder.
Old Sep 20, 2011 | 12:33 PM
  #38
BAJI26's Avatar
BAJI26
It happens in idle, acceleration, deceleration, it happens sporadically!
Old Sep 20, 2011 | 01:08 PM
  #39
BAJI26's Avatar
BAJI26
Arrow I think I've found the problem
I purchase 2 COPs from Napa (Napa Brand:$84) and start doing some swapping and ended @ the last COP on the right bank, it took about 15mins!
So far so good!
Old Sep 20, 2011 | 02:44 PM
  #40
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
knew it!!!! glad you got it fixed!
Old Sep 20, 2011 | 02:58 PM
  #41
neilc88's Avatar
neilc88
So far so good!
Glad to hear you got it fixed. Was $84 for one or 2?
Old Sep 20, 2011 | 05:50 PM
  #42
BAJI26's Avatar
BAJI26
Two!
Gonna pay very close attention for the next few days and get back to ya'll.
Thanks to everyone for your efforts!
Old Sep 24, 2011 | 01:05 PM
  #43
BAJI26's Avatar
BAJI26
Comfirmation
To comfirm it was definately the COP!
Old Oct 10, 2011 | 05:03 PM
  #44
Codelizard's Avatar
Codelizard
Im having a VERY similar issue as I just posted in another tread in detail. Mine started right after gassing up at a new station i'd never used before. Since mine was doing the little ABS/Speedo dance, i ended up replacing the rear abs sensor, but that didnt fix it.
My sputtering happens during accelleration only. During steady driving its smooth, and when i accellerate a little, it sputters. if i give it some extra gas, it smooths out.
So things i saw here that i didnt see in the other thread:
1) Low battery output (my scanguage always reads between 13.5 and 14.5, running or not)
2) dirty egr valve
3) bad coils/boots
Does that about cover it?
Here's more info on my issue:
https://www.ford-trucks.com/forums/1...l#post10905251
Old Oct 10, 2011 | 07:36 PM
  #45
cincyexcursion's Avatar
cincyexcursion
I'll be following this one, because mine is doing the same thing. It's annoying me to no end. Mine also sputters when trying to maintain highway speeds.
