Sputtering X
Old Sep 17, 2011 | 10:58 PM
BAJI26's Avatar
BAJI26
Ok I will go to Autozone tomorrow!
Old Sep 18, 2011 | 12:27 PM
BAJI26's Avatar
BAJI26
Just came back from autozone and no codes thrown!
Where else must I look, the COPs next?
Old Sep 18, 2011 | 02:46 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
thats where i would go... but then again i've had a bad relationship with COP's lol
Old Sep 18, 2011 | 04:39 PM
EXv10's Avatar
EXv10
I would stay away from the cops........lol
Old Sep 18, 2011 | 04:43 PM
EXv10's Avatar
EXv10
It's been my experience that coils are either good or bad and nothing in between, I have a feeling that isn't it.
Old Sep 18, 2011 | 04:53 PM
rlh68050's Avatar
rlh68050
That and the lack of any misfire codes really does not point to the Coils being bad.
Old Sep 18, 2011 | 05:57 PM
EXv10's Avatar
EXv10
If it has been raining there I would say you have water in some of the plug holes, especially the back 3 on the drivers side.
Old Sep 18, 2011 | 06:43 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I've personally had a intermittent miss which turned out to be a coil(or more then one)
Old Sep 18, 2011 | 06:53 PM
EXv10's Avatar
EXv10
Maybe it was a bad connection and you cured it when you changed the coil (and any other related parts). I'v never seen a coil work just part time.
Old Sep 18, 2011 | 06:56 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
nope, it would work fine for a week then the next week start missing again. took them out cleaned them up because the connections were bad at the top of the spring. worked for about another week then started missing again. its very possible and the first place i would look.
Old Sep 18, 2011 | 06:57 PM
69oiler's Avatar
69oiler
i just had this problem with mine, it was intermittent and after changing plugs and boot, changing all the coils is what fixed it for me. after 173k miles it was due.
FYI, if you buy the Motorcraft coils, they come with boots. i wish i had known that, i wasted $50 on boots alone.
Old Sep 19, 2011 | 09:05 AM
rlh68050's Avatar
rlh68050
To the OP. If you have 100k++ miles on your Ex and are still running all the original coils then I would defiantly suggest (as some other posters have) that you change out ALL of them (coils and boots). Go with the Motorcraft for sure. You can get some deals on eBay if you look. The coils (COP's) do degrade over time and I would say that changing them should be part of the preventative maintenance for engines with over 100k on them. Also, if you haven't done the plugs in a while it would be good to do them at the same time as well.
Old Sep 19, 2011 | 09:19 AM
  #28
neilc88's Avatar
neilc88
What is the "ballpark" price for 10 coils?
Old Sep 19, 2011 | 09:21 AM
  #29
jh818's Avatar
jh818
They run about $46 or so a piece.
Old Sep 19, 2011 | 09:51 AM
  #30
69oiler's Avatar
69oiler
I got a set of 8 coils from Rockauto for $350 shipped, last week. I think they had a 15% off sale going. I only got 8 because I had already replaced 2 during the diagnostic process.
