6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
4 wheel drive not engaging
Old Sep 15, 2011 | 04:04 AM
buck1974's Avatar
buck1974
I have a 2008 F-350 with 65k miles, 4 Wheel drive worked about 6 months ago, but not when I needed it over the weekend I could not get the truck to go in 4 high or 4 low. I went through what the manual told me to do, by the book on engaging the 4 wheel drive. I worked and worked forward, reverse in and out back and forth still no results. The light comes on as if it is engaged, however it doesn't work. This is by the selector switch on the dash, this is how I have always used the 4 wheel drive briefly. Also, would something like this be covered under the powertrain warranty?
Old Sep 15, 2011 | 05:06 AM
senix's Avatar
senix
I would be covered under power train warrany but that is only to 60K unless you purchased more.
When you flip the switch does your heat or ac go to defrost only?
Also go out and manually turn the hubs and then hit the switch. Does the front end engage then.
BTW you should manually turn those hubs at least once a month for this very reason.
Old Sep 15, 2011 | 09:45 AM
smartken22's Avatar
smartken22
Also remember for 4 Low to engage, put it in neutral and then go to drive. Repeat for taking out of 4 low.
Old Sep 23, 2011 | 11:24 AM
iracemx6's Avatar
iracemx6
Vacuum pump
Old Oct 8, 2011 | 01:08 PM
pwarren68-2008's Avatar
pwarren68-2008
Manually turn the hubs..has happen to me few times...
frederic nelson
Nov 18, 2023 11:07 AM
irly
6.7L Power Stroke Diesel
Dec 27, 2019 07:05 PM
chevronenza
Dec 16, 2013 08:09 AM
Jager
30
Jan 2, 2009 01:06 AM
EchoEv1
Mar 29, 2007 05:56 PM
