Power Mirror Switch in Right Position Inoperable
Old Sep 13, 2011 | 04:09 PM
makthenif's Avatar
makthenif
Any ideas what is causing this problem?
Old Sep 13, 2011 | 04:53 PM
Herm46's Avatar
Herm46
Try this thread, in my case both mirrors wouldn't move in one direction.
https://www.ford-trucks.com/forums/1...r-mirrors.html
Old Sep 13, 2011 | 04:59 PM
alloro's Avatar
alloro
Do you mean it won't move the mirrors to the right, or do you mean it will operate the driver's mirror, but won't operate the passenger mirror at all?
Old Sep 15, 2011 | 10:55 AM
makthenif's Avatar
makthenif
It won't move the mirror to the right.
Old Sep 15, 2011 | 01:22 PM
alloro's Avatar
alloro
If it's the same for both mirrors then it sounds like the switch needs to be replaced.
Old Sep 15, 2011 | 05:34 PM
Herm46's Avatar
Herm46
If it is both mirrors, that is exactly what mine was doing. The connector to the switch was not seated all the way in, there was a lot of weight pulling on it from the harness going to the window and door lock panel below it.
Old Sep 19, 2011 | 10:12 PM
castrol's Avatar
castrol
Sounds like the contacts in the switch might be corroded. I had a similar problem, except
my mirrors wouldn't move at all. I took the switch out, took it apart, cleaned up all of the
brass contacts and put it back together. My mirrors work perfectly now.
Old Sep 25, 2011 | 10:10 AM
makthenif's Avatar
makthenif
this problem is only on the right mirror. the left mirror is fine.
Old Sep 25, 2011 | 12:36 PM
megawatt00's Avatar
megawatt00
I took mine apart on Friday for the same reason. I will take some pics of the inside. The corrosion looks minimal but it is just enough to prevent them from working.
Old Sep 26, 2011 | 02:24 PM
makthenif's Avatar
makthenif
My next question is how is the mirror removed? Thanks
Baja16
6.7L Power Stroke Diesel
35
Feb 8, 2014 07:03 AM
getnbz
Mar 7, 2009 11:01 AM
dkoenig
Aug 17, 2008 01:38 PM
Club Wagon
1997 - 2003 F150
Oct 20, 2007 05:53 PM
IRULE
1997 - 2003 F150
Apr 3, 2004 05:34 PM
