Injector rebuild
Old Sep 13, 2011 | 02:44 PM
eatont9999's Avatar
eatont9999
Injector rebuild
OK, I need some opinions here. The scenario is I have one bad injector and no functional new injectors to replace it with. I have a set of old injectors and one new injector that my dumb *** cross-threaded the fuel input. Assuming the new injector's internals are up to spec, I disassembled an old injector and the new one. I swapped the top (bolt shaped) part of an old injector with the lower half and internals of the new injector.
I replaced everything as in the way it came out. I tightened the base of the injector to 55 Ft/lbs. I got that number by setting my torque wrench to 60 ft/lbs and then using it to unscrew the bottom half of the new injector. It unscrewed right before the wrench was going to click.
I don't know what the torque is supposed to be, do any of you know? I wonder if this injector will even work. I don't see why not.
Old Sep 13, 2011 | 03:29 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/3...que-specs.html Have a read here.
Old Sep 13, 2011 | 04:43 PM
eatont9999's Avatar
eatont9999
Thanks for your reply but that's not quite what I meant. I disassembled a single injector and swapped the internal parts. I reassembled the injector at 55 ft/lbs and I am wondering if that is the correct torque. I am not installing an injector into the head.
Old Sep 13, 2011 | 04:49 PM
mechmagcn's Avatar
mechmagcn
While the torque is somewhat critical here, I would be more concerned if the pop pressure was affected by the swapping of parts. If you can find someone locally that can check the pressure, it should be good to go.
Old Sep 13, 2011 | 04:50 PM
Lazy K's Avatar
Lazy K
Oops. Misread. I don`t know but I would think you could not be far away at 55ft.lbs.
Old Sep 13, 2011 | 05:00 PM
tecgod13's Avatar
tecgod13
You're correct. Swapping the parts will change the pop pressure. Each injector might be milled slightly different, and the strength of the spring slightly different. That is what the shims in the injector are for. By changing the shim thickness, you alter the pre-load on the spring and thus the pressure it takes to fire the injector. Small changes can be made by tweaking the torque value.
I'm not sure on the spec for the injector torque, its probably not commonly known as the general public wasn't meant to rebuild injectors. I could look up the value for VW injectors if you wanted, but I don't know if that would be of any use.
Old Sep 13, 2011 | 05:10 PM
eatont9999's Avatar
eatont9999
I think I read somewhere that mentioned Mercedes injectors were around 55 ft/lbs. I would take it somewhere to have it pop tested but if it is not perfect, then I run into rebuilding and cleaning fees. It would turn into a $50-$60 injector when I can buy one for $30. I was just screwing around and wondering what people think. I really need to get a pop tester and some rebuilding stuff so I can rebuild injectors and not have to pay other people.
Old Sep 14, 2011 | 03:12 AM
Sycostang67's Avatar
Sycostang67
I went through the same thing, I had to disassemble some injectors to clean them. I tried searching but could not find a torque spec for the end of the injector. The method you used is probably pretty good, though I was told my someone who professionally rebuilds injectors to just get them good and tight.
johndeerefarmer
Jul 24, 2016 07:13 AM
Groundpounder0331
17
Aug 15, 2013 07:04 AM
Visseroth
31
Jul 27, 2011 12:54 AM
EMD_DRIVER
Apr 24, 2011 10:04 PM
caseydudem
29
Oct 19, 2007 09:16 AM
