Big ford cap with points
Old Sep 13, 2011 | 08:52 AM
mkrog's Avatar
mkrog
Question Big ford cap with points
Can I use the big Ford distributor cap with points?,just for troublshooting.
Another ? is there a way to use the Dura spark dizzy with out the control box.I'm pretty sure the answer is no.
Old Sep 13, 2011 | 09:33 AM
rustywheel68's Avatar
rustywheel68
yes, you can use the big cap with a points system. you'll need the spacer, as well.
Old Sep 13, 2011 | 06:25 PM
Franklin2's Avatar
Franklin2
You are correct, you need the module. The sensor/pickup in the dist is for timing and activation of the ignition. The module does the hard work of driving the coil.
66_in_ky
Jun 25, 2009 01:03 PM
Goose_52
Apr 14, 2008 04:11 PM
dgassett
19
Mar 17, 2007 11:04 PM
mkrog
Aug 8, 2005 12:29 PM
Supercab
Jan 31, 2002 09:41 AM
