Ignition Upgrade
Old Jan 22, 2002 | 05:53 AM
Supercab's Avatar
Supercab
Ignition Upgrade
Trying to get parts together to upgrade to the BIG distributor cap & 8mm wires on a 1970 I6, what year should I ask for at my parts store to do this, I've already got a pertronix in the distributor in place of points, also any recomendations on a hotter coil without going overboard???? Thanks!!!
Old Jan 23, 2002 | 10:53 PM
wtroger's Avatar
wtroger
Ignition Upgrade
1974-1983 used the big caps. you want a single vaccume advanced so stay back away from those Autozone asks which you want single or double.
Old Jan 24, 2002 | 04:53 AM
Supercab's Avatar
Supercab
Ignition Upgrade
Do I have to change distributors?? I was under the impression that I could just buy the "adapter" clamp it on in place of the small cap, then attach the big cap & go on, like you can with V8s.
Old Jan 30, 2002 | 09:31 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Ignition Upgrade
Supercab, I think you can get the adapter, top, and rotor for the Duraspark ignition, and it will work on yours.
Be careful on the choice of coils with the Pertronix. If you get one that is much over 40K volts, it will have too much current flow for the Pertronix to handle. You need one that has over 1.5 ohms resistance (I think that's the right value) between the terminals. Pertronix makes one called the "Ignitor", that they recommend with their system.
Old Jan 31, 2002 | 09:14 AM
thelonerangerxlt
Ignition Upgrade
Oops.....The Pertronix coil is called the "Flame-Thrower"....
Old Jan 31, 2002 | 09:41 AM
dsc's Avatar
dsc
Ignition Upgrade
Crop Duster
Mar 7, 2017 09:07 AM
Catanna69
Ford Truck Parts for Sale
Oct 14, 2016 07:37 AM
Oldschool1962
13
Oct 18, 2015 03:30 PM
410F-100
Dec 4, 2010 09:08 PM
cjben
Feb 18, 2005 06:23 AM
