Duraspark ll Cap
Old Apr 10, 2008 | 06:04 PM
Goose_52's Avatar
Goose_52
Duraspark ll Cap
Anyone know if I can use a Duraspark ll cap and adaptor on my 76 distributor? Its a reman, with magentic pickup, which to my understanding is the style needed for Duraspark ll.
Old Apr 13, 2008 | 02:53 AM
fmc400's Avatar
fmc400
MSEE
Yes, you can. If the distributor has the magnetic pickup, that's Duraspark. D1 and D2 are the same in terms of the distributor, the only difference is in the module and it's not major. The Duraspark cap uses a plastic ring adapter like you mention, with a flat cap that has male plug wire connectors. The pre-75 points style cap is a tall one-piece design with female plug wire connectors. You're good to go.
Old Apr 13, 2008 | 03:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Duraspark introduced 1974 in cars & trucks, but not all vehicles have it across the board till 1976.
Parts catalog sez:
D7TZ-12106-A .. Dizzy Cap (Motorcraft DH-370) use with OR without DuraSpark 1975/76 (D7TZ-12106-A replaced D5AZ-12106-A & B7A-12106-A).
1975/76 vehicles use the same dizzy cap with OR without DuraSpark.
E2ZZ-12106-A .. Dizzy Cap (Motorcraft DH-411) use 1977/79.*
E2ZZ-12A217-B .. Adapter [plastic ring] (Motorcraft DJ-6) * use with E2ZZ-A dizzy cap (but was not used with D7TZ-A dizzy cap).
* Updated Ford part numbers, both are still available from FoMoCo.
The same Duraspark stator assy (aka magnetic pickup coil) was used in all V8's (exc 1979's w/EEC) > > 1974/79: D4PZ-12A112-A (Motorcraft DU-1-A)
Old Apr 14, 2008 | 04:11 PM
Tim C's Avatar
Tim C
You can also put the duraspark style cap on the older points distributors, if you add the spacer/adaptor ring and use the duraspark rotor. I did that on my 67 fairlane's 390, to help prevent crossfiring in the cap, since i run msd thats triggered from a pertronix ignitor.
