96' Bronco v8-v10 swap?
There's a thread already about slipping a V10 in an 89 F150. That should give you some great pointers. Too bad it was consumed in the TX fires.
Here it is:
https://www.ford-trucks.com/forums/9...ildthread.html
Here it is:
Subscribed
I had heard when the V10 first came out that one of the reasons they didn't rush to put it into the F-series was that they had to wait for the Superduty redesign to get it to fit. Given that the '96 Bronco is basically an OBS F150 (I believe) engine compartment, you might have some limits that can of course be overcome anyway.
If you're going to do this, you either need a manual tranny with the Ford modular engine bellhousing and a manual transmission PCM for the V10, or the entire engine/tranny/transfer case/PCM from a Superduty.
If your bronco is a manual, this might be easiest. It might be even better to convert an automatic bronco to a manual one BEFORE this swap. The transfer case fitment issues will make a manual tranny and stock transfer case a bit easier to deal with.
Why cant i have a auto trans when i swap to the v10?
My dad has a 02' Excursion limited with the v10 in it and he thinks he has the same t-case and trans as my bronco? is this true?
Plus if i swap to a v10 im going to take the computer and everything from a donor vehicle and put it in my bronco
He didn't say you couldn't have an automatic. He said:
The trans in an '02 Excursion is a 4R100, which is based on the E4OD, but not the same transmission. I'm not sure on the transfer case, but I don't think it's the same either. I'm pretty sure the trans to case bolt patterns are different.
If by "everything" you mean the whole drivetrain down to and including the axles, then you'll be fine. Depending on what size tires you're going to run, your 8.8 may not last that long with that kind of power. I'd probably swap the axles over as well.
Now will the axles in the excursion be better then the ones on my bronco? because on my bronco i have stock Dana44s but swapped gears to detroit 4.10. Is the excursion axle better then that not including the gears?
Ive also read it would be better to take the dash board out of the excursion and put it in the bronco so i have all the same guages. Is this true or could i jus add in a few custom guages?
Lastly, any ideas where i can find performance parts for a v10? or get my hands on a junked excursion/f250/350 that still has good motor/drivetrain in it??
