Turbo barking when cold....
Old Sep 12, 2011 | 06:28 PM
2006powerstroke90's Avatar
2006powerstroke90
Title basically says it...
Only will do it when cold.....a quick accel and when i let off it will bark
Does it need a cleaning?
Old Sep 12, 2011 | 10:34 PM
High Binder's Avatar
High Binder
Tyler, your truck makes me sad.
I would say it needs a cleaning but when mine needed cleaning it would do it at all temps not just cold. Make me wonder if your unison ring is binding.
There also might be a parameter within the PCM that controls the VGT at various temps that out of spec or the VGT sensor might be dirty/malfunctioning.
Just throwing out some ideas.
When was the last time you were in there? Did your unison ring looks ok and if so did you give it a light coating of an anti-seize lube?
Here's mine with a light anti-seize coating. I don't get barking at all.
Old Sep 12, 2011 | 11:40 PM
rdunagan's Avatar
rdunagan
mine does it to id leave it alone. if its not sticking then i would just leave it till it starts cuz all mine have barked when colded. i think its just the nature of the beast
Old Sep 13, 2011 | 05:26 PM
2006powerstroke90
Highbinder- I was in there a while ago...when my EBP tube was clogged, I remember the unison ring where it hooks on the the oval part of like the actuator was worn, I wonder if I should change that out?
Old Sep 13, 2011 | 05:34 PM
High Binder
Well a little wear from the solenoid that drives the variable geometry is probably OK and I could see the wear gradually causing a problem however that being said if the wear was the only factor giving you the barking problem it would happen at all temps. I think you have something else happening but I honestly don't know enough about it. My barking problem happened at all temps and was fixed by giving it a good cleaning.
Barking when cold like Rdunagan's might actually be normal and mine might be the freak non-barker so hopefully somebody will come along to clear that up.
Old Sep 13, 2011 | 06:28 PM
cheezit's Avatar
cheezit
a worn ring can allow over travle of the cam causing it to hang. a change in temps can ruduce the amount of over travle or hanking up do to parts expansion.
also high bender is that high temp anti seize? if not what temp does to change states? I have found when you bake the stuff it can sometimes make things worse and it acts more like a thread locker.
Old Sep 14, 2011 | 06:07 PM
2006powerstroke90
MMMM..intresting...I might order a new ring and then install it/clean the turbo and see what happens
Old Sep 14, 2011 | 10:20 PM
High Binder
Yeah, I used some high temp. I rubbed it into the parts and then 'power' wiped it off. Good call on it baking on and making it act like a glue I figured it would probably goo up especially with the heat and soot.
rotun
Mar 1, 2019 09:10 AM
hs108
Jul 3, 2016 07:06 AM
vectrex
Jun 14, 2013 11:29 PM
wicks302
Nov 10, 2012 04:42 PM
stewart460
Feb 2, 2010 10:31 PM
