fuel leak
Old Sep 14, 2011 | 09:52 PM
zen master's Avatar
zen master
fuel leak
i have a 06 powerstroke with a fuel leak coming from the lower left hand side of motor its cover front axle. it also runs rough at higher rpm til engine comes up to temp. but idles and strats with no problems. any ideals where to start
Old Sep 14, 2011 | 09:55 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Sep 14, 2011 | 10:16 PM
NewToDiesels's Avatar
NewToDiesels
Fuel filters
When was the last time the fuel filters were changed? I had a fuel leak when I first bought truck about a year ago and took it to the dealer. The service rep said to swap filters and then bring it back if it's still leaking. I bought the 2 filters and installed the same afternoon. The leak miraculously stopped. Never did find out where it was coming from.
Rough running until warm could be related to several issues. I'm sure someone with more exp than I will chime in... Again my issues were injector related. Dealer diagnosed driver's bank bad. I replaced them and it runs like a Singer now. What oil are you running?
Old Sep 14, 2011 | 10:22 PM
zen master's Avatar
zen master
replace a month ago cap and top around the filter is dry
Old Sep 14, 2011 | 10:29 PM
NewToDiesels
Did you check the banjo bolts that feed the fuel lines on the front of the motor? You can track them down by tracing the rigid fuel lines that leave the secondary filter and go to the front of both heads. Did you use Ford filters?
Reckless
Mar 28, 2011 12:29 AM
PocaFocus
Jan 23, 2010 01:59 PM
Haakeyez50
Apr 11, 2005 11:14 PM
lindal
Mar 3, 2003 08:50 PM
