Sponsored by: Real Truck
Squealing Noise. Only when i accelerate.
Old Apr 28, 2013 | 03:17 PM
Maddogsvolusia's Avatar
Maddogsvolusia
Thanks man!
Originally Posted by twall_SD250
I did the job myself. The U joints cost about $12 a peice. I didn't use a press I had a ball joint C clamp I used and had no problem at all.
Old Nov 17, 2016 | 08:48 PM
Rick Redmond's Avatar
Rick Redmond
Angry Same issue
I'm having the same issue. this noise is making want to drive the truck off of a bridge. I can hear a light squeak faintly sounds like from the back of the truck as its rolling along in an off-beat pattern then once you're on the accelerator driving you hear a constant squeal and when you let off it goes away. the noise sounds about the pitch of the turbo but louder and more annoying.
Old Nov 18, 2016 | 01:23 PM
Maddogsvolusia
See if you have play in your driveshaft when it is parked and not running. I was able to turn mine, so I pulled the drive shaft and replaced the u joints. Fixed it right up. While i had the drive shaft out, I had it rebalanced as well.
Lusche
Jun 3, 2018 12:06 AM
misterbond
Dec 4, 2016 05:55 PM
TYZ78F150
Sep 26, 2011 02:55 PM
jt371
25
Jun 15, 2010 10:02 PM
G29Knight
Modular V8 (4.6L, 5.4L)
Aug 7, 2008 05:44 AM
