Complicated problem!
Old Sep 12, 2011 | 03:53 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Regular gauge will bounce like mad with the OBS fuel pump.
Just use a tire pressure gauge like mentioned, should get you in the ballpark anyway.
However, the mechanical pump usually has a hard time down low in the rpm (like idle) to keep good fuel flowing, yet will flow well in higher rpm's since it's rpm driven.
There are excpetions, however, and it's still good to know what fuel pressure is.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 12, 2011 | 07:23 PM
bulla's Avatar
bulla
Alright guys, I'll get it checked!
Old Sep 12, 2011 | 10:35 PM
Talyn's Avatar
Talyn
Originally Posted by bulla
Ebps is hooked up but the tube is plugged. Tried to clean it and it made a hole in so it's crimped off down by the manifold. We do have a new tube to try. I guess we should change it.
I'd swap in the new tube honestly.
There has been some debates on what it does.
I've read many a posts on FTE here where people cleaned the tube and their problems went away, or swapped it cause it had a crack and it ran better.
Thats just a WAG anyways.
I'd start with the fuel and CPS like others suggested.
Old Sep 13, 2011 | 05:57 AM
bulla's Avatar
bulla
Thanks William
Old Mar 1, 2012 | 09:19 PM
bulla's Avatar
bulla
Well I hate unfinished threads so let me go ahead and say this one is finished! He found the problem. Turns out it was a faulty map sensor. He got one out of a wrecked truck for free and thought he'd give it a shot. Show nuff, this thing will run! Smoke cleared up, egt's went down, & even out ran a friends sd with 100 hp tune from bts. The owner is super stroked about it. And thanks you guys!
Old Mar 1, 2012 | 09:47 PM
Talyn's Avatar
Talyn
Rock on buddy.
My truck was a dog with a bad MAP sensor.
Old Mar 1, 2012 | 10:14 PM
JonathanN's Avatar
JonathanN
A Dog? Hmmm... might have to try that on this '97. I found a really bad boost leak on the exhaust side (up pipe literally fell outta the collector), but it could be other things. Made no more than 10lbs of boost so I'm thinking the up pipe was the issue. Either way, it couldn't carry itself up a hill at the speed limit. We'll see I guess...
Mike8623
16
Mar 24, 2017 11:50 AM
james_e_j2
Aug 4, 2014 01:00 PM
1_BIGMOFO
Jan 9, 2012 03:40 PM
Diesel_Dirk
Apr 2, 2009 09:23 PM
Tenn01PSD350
22
Jan 19, 2008 02:30 AM
