No Start
Old Sep 10, 2011 | 10:01 PM
bootlakeman's Avatar
bootlakeman
No Start
I have a 06 6.0 with 120,000 on it,changed egr cooler friday,,ran great put 100 or so miles on it,no problems.I want to store today ran fine shut it off went inside now it wont start,cranks fine and fuel pump is running wont start.what should i check?
Old Sep 10, 2011 | 10:19 PM
bismic's Avatar
bismic
Tech Folder : No-Start checklist thread.
Old Sep 11, 2011 | 09:20 AM
2006powerstroke90's Avatar
2006powerstroke90
Did you end up figuring it out??
Old Sep 11, 2011 | 09:24 AM
cheezit's Avatar
cheezit
if you also replaced the oil cooler, check the ipr
Old Sep 11, 2011 | 01:16 PM
Help I M Stuck's Avatar
Help I M Stuck
My truck started doing the same thing. Seems that when it reaches temperature and ran for a while it wont restart. I have to wait till it cools off. From the research I did last night and post reading on No-Start it seems to be the STC connector located on the HPOP that leaks. So it looks like i'll be off to the Ford dealer tomorrow to get the STC kit 4C3Z9B246F and while I have the turbo off I'm going to replace the IPR at the same time. Looks like a whole day of being stretched under the hood.
Old Sep 11, 2011 | 02:29 PM
bootlakeman
I have no codes,f.i.c.m. relay is good,what ,where is the i.p.r and how do you check it?
Old Sep 11, 2011 | 04:41 PM
Help I M Stuck
I had NO codes either. I run a scan gauge. The IPR is located behind the turbo.
little rog
May 19, 2012 05:10 PM
knsahara
Oct 19, 2011 05:30 PM
FireBaller74
Dec 27, 2010 07:21 PM
hndacr
Dec 21, 2009 06:14 PM
