Code 626 and 629 what are they reffering to?
so i just pulled the codes off my 95 ford F150 5.0 automatic..
code 626; coast clutch solenoid circuit fault
code 629; converter clutch solenoid circuit fault or lock up solenoid circuit fault
reason i pulled the codes was because the truck has been shifting rough, can't drive it on the freeway because it wont shift after second.. :/
anyways, i just need to know what this is referring to and if anyone could point me to any charts or diagrams.. whats a good manual for this truck? where are this solenoids located.. etc..
thanks in advance!!!
I know its been a decade, but did you ever get to the bottom of this issue? I have had the 626 code for years and the trucks runs fine until you put it into drive Just need to know if solenoid is accessible from outside. Cannot find location of it.
I love the help this forum offered you (NOTHING AT ALL)! Transmission advice from technicians won't happen (they want $$), and most mechanics know very little about them.
Larry
Larry
Always get the 626 code (coast clutch solenoid circuit fault). Cant remember if that solenoid was in the pack installed.
I am leaning toward transmission replacement.
I only use this for picking up stuff from Home Depot or runs to disposal yard. Not a daily driving machine.
