E4OD plug wiring diagram/ color codes
Old Feb 24, 2018 | 09:59 AM
dtrm's Avatar
dtrm
I have a 93 F250 4wd with a 460 and an E4OD transmission. The previous owner did an extensive rebuild done of the transmission, and added a Banks Trans Command system, and it has failed. To install the trans command, they pulled three wires from the plug going into the transmission, which are replaced by wires from the trans command system. I'm looking for a wiring diagram that shows which of the three factory colored wires goes into which of the pins in the factory plug. Thanks in advance!
Old Feb 27, 2018 | 07:13 PM
Scndsin's Avatar
Scndsin
Bump to the top of forum.
Good luck.
Old Feb 27, 2018 | 08:38 PM
wag53's Avatar
wag53
e4od-harness-connector.jpg I think this is what you are looking for.
Old Feb 28, 2018 | 06:15 AM
dtrm's Avatar
dtrm
Thank you. Almost there, removed the trans command, and it's well again.
Old Feb 28, 2018 | 07:42 AM
subford's Avatar
subford
Here is the diagram:
Attachment 282875
Old Feb 28, 2018 | 07:49 AM
dtrm's Avatar
dtrm
Thank you !
Old Sep 16, 2022 | 09:37 AM
IBEWelectronut's Avatar
IBEWelectronut
What year truck is this diagram for?
Old Sep 16, 2022 | 09:44 AM
Scndsin's Avatar
Scndsin
OP, 1st post.
Old Jan 1, 2024 | 04:57 AM
Nick1996 fleetwood460a4od's Avatar
4th Gear
nice stang
Wow on the description of what's on the stang. Ive a 73conv. with the old 351 cl...in beginers stages ( and low Budget!!)
need toknow what headers to look for thatll fit the stock exhustm... shortys?
Old Jan 1, 2024 | 05:06 AM
charlie g's Avatar
charlie g
FTE Community Team
welcome to the site but please take note this is a dead near 6 year old thread , as to your mustang try https://www.vintage-mustang.com/
Old Jan 2, 2024 | 11:11 AM
4th Gear
What is this???
Thank you sir... I am really trying to fix/troubleshoot a94 F53 chasis (fleetwood bounder) ford 460 E4OD that went into neutral on me on I 10 and Possibly overheated . Haven't run codes yet(. Im working on getting a scanner or figuring that task out . For now towed it back to my house in panama city beach and have pulled the mlps cleaned it ... and fluid smells funny so am dropping pan today. Just trying tom learn from this and am not a wealthy enough person to take er to a shop. My dads last purchase was the camper then he fell and couldnt recover and passed. Very sentimental to me... Learning a lot of patience. Read a lot of Mark Kovalsky's posts.... Sir appreciate what ever knowledge you may be able bless me with... Thank you
Just want to see if any one can confirmmthat I have an E4OD... this s stampped on it
ehusmann
Jul 29, 2019 02:14 PM
zottyzot
Nov 15, 2012 12:40 PM
jdwoody
Mar 19, 2011 01:57 PM
Tsaven Nava
Aug 24, 2006 09:54 PM
