Sponsored by: Real Truck
PCM code reader
Old Jan 7, 2010 | 11:29 PM
Johnny Bravo 45's Avatar
Johnny Bravo 45
PCM code reader
DO I really need to purchase a code reader for my OBD 2 Truck that is a 2002 F 250 SuperDuty?
I have a GMC typhoon and I can just put a wire between the A and B terminal to get my codes on it. I was hoping there is a similar way to get the codes on my new/used truck
Thank You
Old Jan 7, 2010 | 11:40 PM
biz4two's Avatar
biz4two
Arrow
Absolutely need a code reader. Keep in mind that even though the connector is an OBDII compliant type...the 2002 (actually '99-'03) SuperDuty Trucks that are not California smog compliant...are only OBDI with regards to the PCM (ECM). It has to do with being over 8500 GVWR...and the emission laws at that time. Hope this helps...
OBTW: I purchased an Equus product and really like it.
OBDII (Vehicles 1996 and newer) - EQUUS PRODUCTS, INC.
Welcome to FTE...
Good luck...
biz
Old Jan 8, 2010 | 12:23 AM
Johnny Bravo 45
Hmm,
I was hoping my new truck would do as my Typhoon does. I jump the ALDL port on my GMC Ty, and my service engine soon light flashes a sequence of 1, then 2 pause X 3 times = code 12 which is says..all is good. IF I throw any codes in the Ty, they will follow the 12 code. Example, it will flast a 12 3x, then if I have an EGR code, 32 3x, then on to the next code, or it will tell me no more codes are flagged by going back to a code 12.
I have seen similar code readers on the link you provided for my GMC TY, and they don't do more than putting a piece of wire in the A and B terminals of the ALDL, then watching the codes displayed on the dash via the service light. The only thing the code reader does is tell you on a display the actual code that's flagged. Now, my Ty is OBD 1, but there's gotta be a simple way to jump the port to retrieve the codes on the OBD 2.
I know the ALDL is called something different on a Ford, but same thing.
.....So, your telling me I can't just jump the port on my F250
Old Jan 8, 2010 | 09:05 AM
GUNNERDOG's Avatar
GUNNERDOG
On my jeep you had to turn the key to run three times with the odometer button held down... then it would display codes on the odometer readout.
Haven't found anything like that for my truck though.
Old Jan 8, 2010 | 10:05 AM
tex25025's Avatar
tex25025
To my knowledge there isn't anything like that on these trucks. I could be wrong, but I haven't heard or seen anything about it. Also I missed what engine you have in there as well? Not all engines follow the same communication line and require very specific code readers.
Also, I don't get what your aversion is to a code reader? I use mine all the time and not just for DTC retrieval either. There is alot of stuff that you can do with the computer controlled vehicles that make things easier and less time consuming.
Old Jan 8, 2010 | 10:53 AM
dkf's Avatar
dkf
OBD I is setup to test as you described with flashing certain signals and some readers can pull from the OD2 port. Best thing for the 99'up SDs is to get a code reader to read the DTCs.
steveamann
13
May 5, 2013 03:33 PM
raptor2005
Feb 15, 2010 03:03 PM
roybus14
Computer Chips & Tuners
Feb 3, 2007 10:25 AM
BodegaErik
Jul 2, 2006 02:41 AM
88fordf150
Sep 2, 2005 05:26 PM
